97gsxIA
- 419
- 45
- Apr 22, 2011
Des Moines,
Iowa
Ok so as the title states, I had a spark plug strip out (took plugs out and tightened them way too many times apparently).
I used a spark plug repair kit, retapped the hole and placed the insert in with red loctite. I used the taller insert available which i believe is the correct one. The very top (seat) of the insert broke a little as a tightened it in ( Much swearing ensued and this is what I think is my problem.) Low and behold, 60psi compression in that cylinder and motor runs like shit at 10in/Hg Vac... I doubt I nicked a valve in this process, but what are the chances?
The tap was straight and besides being tough on the hands, wasn't that difficult to perform.
So, I need to pull the head and take this insert out and retry with a different one. Problem being red loctite on the threads.
You think some JB weld on the threads of a plug, insert it... let it cure.. and pull it out would work? I am not a fan of trying to tap an even larger hole.
Let me know what you think.
