1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
2G Factory Boost Control Solenoid part number
Posted by ileagleracing, Dec 7, 2018
Please Support Ace Race Parts
  1. ileagleracing
    ileagleracing Supporting Member
    208
    94
    Joined Sep 27, 2007
    Stratford, Connecticut
    Does anyone know the Mitsubishi part number for the BCS (Wastegate) Solenoid?
    Log in/Register to remove ads
    My DSM:
    1995 Eagle Talon TSi AWD
    Autocross Build
    160 whp   190 lb/ft
    1998 Eagle Talon TSi AWD
    Autocross Build
    313 whp   305 lb/ft
    Loading...
    Featured Products from our Supporting Vendors
  2. 007jimmy
    007jimmy Proven Member
    1,440
    62
    Joined Feb 27, 2012
    Levittown, Pennsylvania
    CD87A97A-55C2-42A2-8D69-FD0FF2CD706D.jpeg I believe it’s the same as the EGR solenoid except that it has a restrictor in the bottom port. 1g and 2g BCS are different looking so the part number is most likely different. The one above is a 2g
    My DSM:
    1997 Mitsubishi Eclipse GSX
    Street Build
      automatic
    Loading...
  3. ileagleracing
    208
    94
    Joined Sep 27, 2007
    For some reason I have a couple EGR solenoids laying around and they are different than what you have there, never thought to search by that part number, was looking for a Mitsubishi number and having no luck. I'll try K5T47698
    My DSM:
    Autocross Build
    160 whp   190 lb/ft
    Autocross Build
    313 whp   305 lb/ft
    Loading...
  4. luv2rallye
    luv2rallye DSM Wiseman
    7,403
    478
    Joined Jun 7, 2003
    Minneapolis, Minnesota
    That's not a factory part number. Factory number should be MR312748.
    My DSM:
    1999 Mitsubishi Eclipse GST
    14.200 @ 95.000 MPH
    Loading...
  5. Kryndon
    Kryndon Proven Member
    220
    63
    Joined Jan 10, 2014
    Bulgaria, Europe
    Luv2rallye, not trying to argue with a wiseman but that part number comes up as the '96-'97 evap solenoid. For the BCS itself (along with the little bracket it comes with), the part number I can see is MR127560. Or just MD145201 for the solenoid unit itself. Here's a pic; unless the database I'm using is outdated but I've used it hundreds of times and always got the right parts. I think it's based off CAPS.
    My DSM:
    1997 Eagle Talon TSi AWD
    Street Build
    14.769 @ 92.22 MPH
    Loading...
  6. luv2rallye
    7,403
    478
    Joined Jun 7, 2003
    You're right, good catch. Glad someone is checking me.
    My DSM:
    14.200 @ 95.000 MPH
    Loading...
    Kryndon likes this.
  7. ileagleracing
    208
    94
    Joined Sep 27, 2007
    Those Mitsubishi part numbers were what I was looking for, unfortunately they aren't even in the OEM online parts catalogs anymore.
    I was able to find a couple used using the "K" number, fingers crossed that they are any better than the one I've got in the car.
    My DSM:
    Autocross Build
    160 whp   190 lb/ft
    Autocross Build
    313 whp   305 lb/ft
    Loading...
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
