HarleyD2g
- 38
- 2
- Feb 18, 2017
Baker,
Montana
What would be a good set up for a DD but also have some pep ??
Note: This feature currently requires accessing the site using the built-in Safari browser.
He want's a 1000hp daily-driven car that can also be used in the coming apocalypse.You have no profile so we have no idea what you are working with. Question is entirely too vague. A good setup to do what? Are you building a mud bog car, a drag car, show car? A "good" setup means different things for different builds. Above all the car needs to be in Tip-Top mechanical shape. All maintenance must be up to date and I mean all. Only then should you start modifying the car
