Please Support STM Tuned
Please Support ExtremePSI
General Evo 8 ECU in auto 2g
BasketcaseTSI
5+ Year Contributor
70
11
Feb 11, 2018
South Haven, Michigan
I'm leaving towards the Evo ECU in my Talon since it appears to be cheaper than DSMLink (I would go with link if I had more money to spend).
Anyways, I've read a few threads on it but, it seems like the people are using the Evo ECU have manual transmissions. Has anyone one here swapped a Evo ECU into an auto car? I just need some insight on the additional wiring. If it helps, I've already got the service manual set for my Talon.
I have the 3g ECU with Tephra v7 in mine. It shifts some of the time from what I noticed. Then I think it stops shifting and goes into limp mode. From what I did notice any ways. Not 100% sure. I haven’t driven in her while.
Good call. I'm used to GM PCMs from my previous modded cars. I can't believe I totally forgot about the TCU. I guess I'll be doing some harness changes in the near future.
It only uses a few ECU parameters actually, and some are for things like cruise control. The ECU outputs can still be fed to the TCU.
Well, I started the adventure. I picked up an open ECU cable, evoscan/ecuflash, a 01 Eclipse 4cyl manual ECU, I started repinning the harness and I downloaded a couple ROMs. It feels good to finally be doing something with it.
Just curious if you've made any progress on this?
I'm looking to setup my 96 gsx auto.
