- Thread starter
- #51
Sirnixalot
- 328
- 11
- Jun 5, 2010
Cayman Islands,
Central_America
Well i got it up and running It definitely needs a retune though.
I managed to leave the RTV too long to set up on the oil pan so i have a small leak from the front of the pan and i tore an axle boot. The shop i used to work at has the car and is gonna take care of that for me tomorrow since i really don't have any time this week to get under the car (read i am being lazy)
I should be doing some idle fuel trim logs tomorrow after work and MAYBE some cruising logs for the mid trims.
I know its not the best vid but here is more proof that the Evo 8 cams can be made to work in our head. I am running an Evo 3/DSM HKS 272* intake and an Evo 8 280* exhaust cam.(if you consider a video that is basically darkness with one head light on and a car idling on the word of a complete stranger proof)
If you have cam gears that have the dowel holes for both the DSM and Evo applications then its even easier. I just rotated the inner hub of my cam gear to point the Evo 8 cam dowel to the front of the car which left the cam timing marks alone to make things easier to time up. (Evo 8 dowels point out and DSM dowels point up)
The car is definitely lacking some low end and it is a little "laggy". 2.3L spoiled me for sure.
Look for autocross vids end of month!
*EDIT*
MUCH better vid of the sound at idle (1200rpm need to work on that and get it down to at least 1000rpm)
Idling temps The AFCO scirocco rad, twin 750cfm fans and Ralliart thermostat (160*F) are working nicely. The oil cooler thermostat is a 71*C unit from HKS so all appears to be well on the idling front. I will report back after some logging 3rd gear pulls.
The Apexi gauge is in *C (oil) and the Summit red LED gauge is in *F (coolant)
*EDIT*
