Evo-3 16G Turbo
Posted by Psyclone, Aug 30, 2012
Turbo System Tech - 4G63 turbos, Intercooling, Boost Control, Wastegates, etc.
  1. Psyclone
    Psyclone Proven Member
    DSM Profiles:
    Mar 22, 2012
    54
    Waco, Texas
    Ok, So I just bought a Evo 3 16G turbo from a friend. I have several questions about where to go from here.
    1. It has a minimal bit of back and forth shaft play but no side to side shaft play. Should I take it apart and port and polish every thing and fix the shaft play?
    2. What company makes the best adapter kit for the 2gb GSX?
    3. Should I leave it as an external type waste gate (have to get the parts for it) Or should I see if I can find a original internal waste gate actuator to use the internal function?
    Thanks
    #1
  2. iugrad92turbo
    iugrad92turbo Proven Member
    DSM Profiles:
    May 22, 2007
    10,155
    205
    Kalamazoo, Michigan
    Just rebuild it, and look for prices on the vendor sites.
    #2
  3. Jesse2012
    Jesse2012 Proven Member
    DSM Profiles:
    Jan 25, 2011
    230
    Rochester, New_York
    If you're talking about an install kit ..
    #3
  4. dsmAB
    dsmAB Proven Member
    DSM Profiles:
    Mar 17, 2011
    69
    13
    Edmonton, AB_Canada
    i would say go ahead and keep the external setup for the wastegate if you got the funds, because the e316g likes to boost creep.
    #4
  5. TSITurbo95
    TSITurbo95 Proven Member
    Oct 26, 2009
    1,312
    10
    Ohio, Ohio
    In and out play is a no no. Depending on how much in and out there is, you may already need a compressor wheel. Either rebuild it, or get it rebuilt. . .
    #5
  6. JusMX141
    JusMX141 Moderator
    DSM Profiles:
    4
    Dec 13, 2005
    12,534
    474
    Greensburg, Pennsylvania
    If it's a Genuine MHI turbo, do NOT run it without rebuilding it first. That thrust wear is going to get worse rapidly.
    If it's a knockoff Chinese special, throw it away and buy a Genuine MHI turbo.
    #6
  7. Psyclone
    DSM Profiles:
    Mar 22, 2012
    54
    Waco, Texas
    Guess I'll start looking for the parts, any suggestions? (Don't have a lot of funds, but I can save for things, and I believe in doing it right the first time.)
    Also, I am starting to disassemble it today, also buying a rebuild kit, going to port and polish it to. Will post pictures (warning, it may take some time due to my work schedule. :ohdamn:)
    #7
  8. dsmAB
    dsmAB Proven Member
    DSM Profiles:
    Mar 17, 2011
    69
    13
    Edmonton, AB_Canada
    I found that on classifieds you can find a 38mm tial ewg for like 75-150ish and then the external wastegate flanged o2 housing can be had for like 150 if you find a good deal.
    #8
  9. mb3000
    mb3000 Proven Member
    Aug 9, 2011
    60
    Myrtle Beach, South_Carolina
    If you've got that thing disassembled, would you mind getting a measurement for me? I'd like to know the diameter of the turbine or chra flange that joins the two together. I'm pretty sure it's 3" but don't have one in front of me to verify.
    Measurement similar to this:
    [​IMG]
    #9
  10. 99 gs iowa
    99 gs iowa Proven Member
    DSM Profiles:
    May 29, 2011
    226
    moravia, Iowa
    id so some fuel mods/ wideband, dsmlink, before jus throwing this turbo on your car,
    #10
  11. Psyclone
    DSM Profiles:
    Mar 22, 2012
    54
    Waco, Texas
    Fuel will upgrade to a 450 Walbro, 750 injectors, and a new regulator or some variety.
    will be installing glow shift: boost, EGT, and oil pressure gauges. Also installing an Auto Meter A/F ratio gauge.
    DSM link
    EVO III Intake Manifold and throttle body, and a VRSF FMIC.
    DNP Exhaust header with tiAl external waste gate.
    #11
  12. Cdc1221
    Cdc1221 Proven Member
    DSM Profiles:
    Feb 16, 2012
    1,013
    Jackson, Georgia
    You realise that a/f ratio gauge is a waste of money right? Just trying to help you save money for a wb o2
    #12
  13. MJcanada
    MJcanada Proven Member
    DSM Profiles:
    Jun 25, 2011
    2,107
    36
    campabello, South_Carolina
    Both if these are uneeded. 255lph and a lc-1 wideband should replace these two.
    #13
  14. hocka09
    hocka09 Proven Member
    DSM Profiles:
    Aug 8, 2010
    105
    Macomb, Michigan
    He sounds fairly knowledgeable about his build plan, I would imagine he meant a wb by that statement.
    #14
  15. Psyclone
    DSM Profiles:
    Mar 22, 2012
    54
    Waco, Texas
    Indeed I did sir.
    #15
  16. Roberti 2G
    Roberti 2G Supporting Member
    DSM Profiles:
    Mar 5, 2012
    308
    14
    Holloman AFB, New_Mexico
    The 450 pump is a little over kill.
    #16
  17. Cdc1221
    DSM Profiles:
    Feb 16, 2012
    1,013
    Jackson, Georgia
    I forgot i wasnt posting in the newb section LOL:D
    #17
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
