Evo 1 Gsr Awd Lsd Transmission In 2g
Posted by keltalon, Oct 17, 2015
Please Support Magnus Motorsports
  1. keltalon
    keltalon Supporting VIP
    3,277
    941
    Joined Jun 29, 2003
    Luthersville Ga, Atlanta, Georgia
    Okay I recently mixed some gears on my fwd transmission build and it turned out very successful. I ended up using 1997 1rst and 2nd gear and 1990 3rd and 4th gears the transmission turned out absolutely amazing shift quality was awesome everything was cryo treated , shot peened and wpc treated I have going to start another fwd project later down the road. Now that I have an Awd project I want to do the same thing. I want to use the 1990 3rd and 4th gears in my current 2g Awd transmission. I have been doing a lot of reading and found that there are a few more items to try and match so as to keep all gear ratios matched between transfer case and transmission than the fwd gut swap. The current Awd tranny in the car is 23 spline with matching transfer case and the 1990 unit is 21 spline in which I don't have a transfer case. I will get the numbers off the awd tranny and post them just so that we all know what year 2g awd tranny I have. I know Tim has a lot of information on this for he is the one who let me know exactly what to lookout for on the fwd gut swap. Tim if your input is greatly appreciated. Also let me know what center diff I need to send in to you to have the 4 spider machining done. thank!
    Log in/Register to remove ads
    My DSM:
    1998 Mitsubishi Eclipse GSX
    Street Build
    16g   manual
    Loading...
    BlackWidow likes this.
  2. keltalon
    3,277
    941
    Joined Jun 29, 2003
    My DSM:
    Street Build
    16g   manual
    Loading...
  3. keltalon
    3,277
    941
    Joined Jun 29, 2003
    Okay just found out that I have something kind of rare in my possession:D can someone confirm the transmission vin code please.
    W5M33-2-WQWE...92-93 Evo1 GSR (and RS?) (viscous front LSD) (3.909
    My DSM:
    Street Build
    16g   manual
    Loading...
    buddahboost likes this.
  4. Dsmkauai
    Dsmkauai Proven Member
    3,916
    414
    Joined Feb 20, 2010
    Kauai, Hawaii
    I'll send it over to Brian Terhune he will know for sure :). Can't wait my trans for the gvr4 is about to be delivered! Time to unleash the beast haha, well as soon as my built 4bolt arrives anyway. Looking forward to see your progress kels ;)
    My DSM:
    Loading...
    keltalon likes this.
  5. Dsmkauai
    3,916
    414
    Joined Feb 20, 2010
    Kauai, Hawaii
    Brian confirmed evo1 with LSD!
    My DSM:
    Loading...
  6. keltalon
    3,277
    941
    Joined Jun 29, 2003
    Now at this point this is a game changer for sure in my transmission plans!!
    Nice!
    My DSM:
    Street Build
    16g   manual
    Loading...
  7. keltalon
    3,277
    941
    Joined Jun 29, 2003
    I am wondering do I use the same rebuild kit for the two hole shift fork?
    My DSM:
    Street Build
    16g   manual
    Loading...
  8. pauleyman
    pauleyman DSM Wiseman
    4,522
    733
    Joined Nov 19, 2011
    oklahoma city, Oklahoma
    Take it apart and you will know whats in it. Gear ratios for dsm tranies are the same. Evo isnt. Some important changes are involute of 3rd gear/cctr diff and final drive of front diff from 90-96 vs 97 up.
    My DSM:
    1997 Eagle Talon TSi AWD
    Street Build
    T25   manual
    Loading...
  9. keltalon
    3,277
    941
    Joined Jun 29, 2003
    1. twicks69 DSM Wiseman
    " The Evo 1 transmission is different in several ways from either the Evo 2 or Evo 3 transmission internally though and only shares the same final drive (pinion output shaft and ring gear), 5th/Reverse gearset and hub/slider assembly, and a few other parts.
    The Evo 1 does have the tallest 1st gear ratio available from OEM mitsubishi parts for the W5M33 transmission. The Evo 1 1st gear is 2.571:1 ratio, the Evo 2/3 1st gear is 2.751:1 ratio, and the DSM 1st gear is 3.083:1 ratio, and the Galant VR4 1st gear is 2.846:1 ratio. Being that the Evo 1 had such a tall ratio 1st gear, the reverse idler gear lever arm was a different shape to clear the gear, so if you ever find an Evo 1 1st gear/2nd gear/input shaft, you will need to either clearance your DSM or GVR4 rail lever to fit the gear or find an Evo 1 rail lever (nearly impossible).
    The Evo 1 also had solid steel shift forks, and solid steel shift rails/rail ends that were extremely beefy. The downside to the transmission was that it did not come with a shot-peened input shaft or gearset while the Evo 2/3 did have shotpeening work on certain parts done from the manufacturer.
    All Evo 1/2/3 transmissions had options of either an open front differential or a clutch-type LSD front differential. All Evo 1/2/3 transmissions came with a standard 2-spider viscous center differential.
    Unfortunately, the Evo 1 solid steel shift forks and rails are no longer available from Mitsubishi.
    Hopefully this random information is helpful to you or anyone else.
    1. To give you an idea of what the Evo 1 first gear means for insanely tall, here is a breakdown of the DSM 3.545 final drive ratio being used on the following 1st gear options on a 25" diameter tire:
      DSM AWD (3.083)
      2000rpm =14 mph
      3000rpm =20 mph
      4000rpm =27 mph
      5000rpm =34 mph
      6000rpm =41 mph
      7000rpm =48 mph
      8000rpm =54 mph
      9000rpm =61 mph
      10000rpm =68 mph
      Galant VR-4 (2.846) (8.5% taller)
      2000rpm =15 mph
      3000rpm =22 mph
      4000rpm =29 mph
      5000rpm =37 mph
      6000rpm =44 mph
      7000rpm =51 mph
      8000rpm =59 mph
      9000rpm =66 mph
      10000rpm =74 mph
      Evo 2/3 (2.751) (12% taller)
      2000rpm =15 mph
      3000rpm =23 mph
      4000rpm =30 mph
      5000rpm =38 mph
      6000rpm =46 mph
      7000rpm =53 mph
      8000rpm =61 mph
      9000rpm =69 mph
      10000rpm =76 mph
      Evo 1 (2.571) (20% taller)
      2000rpm =16 mph
      3000rpm =24 mph
      4000rpm =33 mph
      5000rpm =41 mph
      6000rpm =49 mph
      7000rpm =57 mph
      8000rpm =65 mph
      9000rpm =73 mph
      10000rpm =82 mph
      The Evo 1 Input shaft, 1st gear and 2nd gear are a matched set. They must be used together as the 2nd gear is 5% taller than a DSM or Evo 2/3 2nd gear.
      The downfall to the stock Evo 1 transmission case is only the lack of shot-peening of parts from the factory, and the lack of double synchros. Other than that, it is a fun transmission because of the tall 1st/2nd, the close-ratio 4% shorter 3rd and 4% shorter 4th, and the 8% taller 5th.
    My DSM:
    Street Build
    16g   manual
    Loading...
    iugrad92turbo likes this.
  10. CrackedDSM
    CrackedDSM Proven Member
    733
    227
    Joined Dec 17, 2009
    High Point, North Carolina
    It sounds like Kel struck gold. You can shot peen those parts easily, and have them machined/modified for double synchros. Or you could get them faceplated.
    Good information Kelvin!
    My DSM:
    1995 Eagle Talon TSi AWD
    Street Build
    16g   automatic
    1991 Mitsubishi Eclipse GSX (sold)
    12.530 @ 111.000 MPH
    Loading...
  11. keltalon
    3,277
    941
    Joined Jun 29, 2003
    I was ask to take a picture of the differential where the axles slide in he said a True lsd will be hollow all the way through. tmp_24230-VZM.IMG_20151017_180457-1972998623.jpg
    My DSM:
    Street Build
    16g   manual
    Loading...
    BlackWidow and CrackedDSM like this.
  12. keltalon
    3,277
    941
    Joined Jun 29, 2003
    As I gather information on this tranny I will be posting it here so that it all in one place for quick reference.
    My DSM:
    Street Build
    16g   manual
    Loading...
  13. keltalon
    3,277
    941
    Joined Jun 29, 2003
    Taken from evo forum:cool:
    EVO I CD9A: GEAR RATIOS INPUT/INTERMEDIATE:
    1st - 14/36 = 2.571
    2nd – 20/32 = 1.600
    3rd - 25/29 = 1.160
    4th - 29/25 = 0.862
    5th - 34/21 = 0.617
    GEARBOX CODES:
    WQGE-GSR no LSD
    WQWE-GSR with viscous front LSD (The one I have)
    WQYE-RS no LSD
    WQFE-RS with viscous front LSD
    selector ring size is 96.8 on input and 96.8 on int
    EVO I Front Diff Crownwheel = 64 teeth
    EVO I output shaft = 15 teeth
    Front Diff Ratio = 64/15 = 4.266
    Output shaft to transfer case = 23 teeth
    Transfer ratio = 1.09
    Rear diff ratio = 3.545
    Rear diff ratio: 3.909
    EVO II-III CE9A: (EVO III has slightly different transfer and front diff ratio)
    GEAR RATIOS INPUT/INTERMEDIATE :
    1st - 12/33 = 2.750
    2nd – 19/32 = 1.684
    3rd - 25/29 = 1.160
    4th - 29/25 = 0.862
    5th - 34/21 = 0.617
    GEARBOX CODES EVO II
    WPGE-GSR no LSD
    WPWE-GSR with viscous front LSD
    WPYE-RS no LSD
    WPFE-RS with viscous front LSD
    selector ring 92.9 input 97.2 int
    EVO II Front Diff Crownwheel = 64 teeth
    EVO II output shaft = 15 teeth
    EVO II Front Diff Ratio = 64/15 = 4.266
    EVO II Transfer ratio = 1.09
    GEARBOX CODES EVO III
    UPGE-GSR no LSD
    UPWE-GSR with viscous front LSD
    UPYE-RS no LSD
    UPFE-RS with viscous front LSD
    EVO III Front Diff Crownwheel = 63 teeth
    EVO III output shaft = 15 teeth
    EVO III Front Diff Ratio = 63/15 = 4.200
    EVO III Transfer ratio = 1.074
    GSR LANCER CD5A:
    1st – 12/35 = 2.917
    2nd – 19/32 = 1.684
    3rd – 26/29 = 1.115
    4th – 30/25 = 0.833
    5th – 33/22 = 0.666
    GEARBOX CODES
    NRBE-GSR no LSD
    NRWE-GSR with viscous front LSD.
    GSR Front Diff Crownwheel = 58 teeth
    GSR output shaft = 15 teeth
    Front Diff Ratio = 58/15 = 3.866
    Rear diff ratio: 3.545 (39/11)
    1G DSM AWD W5M33-2-NPXV Gearbox code.
    Fitted to 91-94 Eclipse AWD 5spd manufactured between 6/90 - 2/94.
    The 1G AWD manual transmission actually shares the same input and intermediate shafts as our CD5A GSR Lancer's do.
    It actually shares quite a lot the same as our GSR boxes and only difference is a different 1st and 3rd gear cog to the GSR!!
    1st gear = 12/37 = 3.083 (1G specific 37 tooth gear cog which lives on the intermediate shaft).
    2nd gear = 19/32 = 1.684 (same tooth count as GSR and EVO I-III) Note: EVO 1 uses a completely different gear. All are double synchro.
    3rd gear = 25/29 = 1.160 (same tooth count as EVO I-III) Note: But EVO II-III use double synchro 3rd gear sets.
    4th gear = 30/25 = 0.8333 (same as GSR) Single synchro.
    5th gear = 33/22 = 0.666 (same as GSR) Single synchro.
    Reverse = 3.166
    1G Front Diff Crownwheel = 58 teeth
    1G output shaft = 15 teeth
    Here are the DSM gearbox ratios to compare to: http://www.vfaq.com/mods/Trannies.html
    My DSM:
    Street Build
    16g   manual
    Loading...
    BlackWidow and ceedawg like this.
  14. keltalon
    3,277
    941
    Joined Jun 29, 2003
    Just found out the transfer case on the car is definitely from a 1995-96 2g 58 tooth ring gear. Once I crack open the transmission I will see of the ring gear has been changed from the jdm tranny to match, from the looks of it I doubt it. This also will be corrected during the bullet proofing of the tranny.
    My DSM:
    Street Build
    16g   manual
    Loading...
  15. keltalon
    3,277
    941
    Joined Jun 29, 2003
    Some more information gathered from evo forum.
    EVO I-III RATIOS:
    Info I've gathered and discovered over time and summarised below.
    TRANSFER CASES:
    * VR4 gearbox + VR4 transfer case input spline count = 22 (You will need a 1.090 VR4 transfer case when using a VR4 gearbox as its the only transfer case to suit the gearbox output shaft's spline count) = 3.545 rear diff ratio result. NOTE: VR4 EVO have a 23 spline count therefore refer to below GSR stats.
    * GSR gearbox + GSR transfer case input spline count = 23 (You can mix and match a GSR gearbox with a GSR or EVO I-II 1.090 transfer case only) = 3.545 rear diff ratio result
    * EVO I-II gearbox + EVO I-II transfer case input spline count= 23 (You can mix and match EVO I-II gearbox with GSR or EVO I-II 1.090 transfer cases only) = 3.909 rear diff ratio result
    * EVO III gearbox + EVO III transfer case input spline count = 23 (You MUST USE the EVO III 1.074 transfer case with the EVO III gearbox only as it corrects the ratio to accept a 3.909 rear diff) = 3.909 rear diff ratio result
    REAR DIFFS:
    * First thing's first. All EVO I-III rear diff ratios are 3.909. All EVO I-III RS/GSR had a rear mechancial LSD diff centre, except the EVO 1 GSR which had a viscious LSD rear centre with different length rear driveshaft cups and shafts.
    * If you are using an EVO III gearbox, YOU MUST also use an EVO III transfer case to correct the rear ratio to 3.909 - this will suit any of the EVO I-III 3.909 rear diffs.
    * To make an EVO rear mech LSD a ratio of 3.545 to suit a E39A Galant VR4 or GSR 3.545 gearbox - Simply keep your existing GSR or VR4 rear diff housing, remove the diff centre and remove the 3.545 crown wheel and pinion from it. Get an EVO rear mech LSD centre, and transfer your 3.545 crown wheel and pinion into it.
    The replaced parts will NEED to be done by a professional as they need to setup the backlash and tooth contact correctly. If its a tiny bit off you're screwed. This can then go back into your existing housing and your existing axles can plug straight in.
    __________________________________________________
    The gear ratios are on lancerregister.com under 'evo 1-3 buyers guide'
    Here they are anyway:
    EVO I:
    2.571 (1st)
    1.600
    1.160
    0.862
    0.617 (5th)
    Rear diff: 3.909
    EVO II-III: (EVO III has slightly different transfer and front diff ratio)
    2.750 (1st)
    1.684
    1.160
    0.862
    0.617 (5th)
    Rear diff: 3.909
    GSR: (CD5A)
    2.917 (1st)
    1.684
    1.115
    0.833
    0.666 (5th)
    Rear diff: 3.545
    I have also got some info on EVO/GSR/VR4 diff and transfer case ratios below which I got from NZ MMC:
    VR4s and GSRs:
    1.090 Transfer ratio (TR) (24/22)
    3.867 (58/15) front diff ratio. (FDR)
    3.545 (39/11) Rear diff ratio (RDR)
    RDR x TR = 3.866 combined rear final drive
    Total final Drive ratio TFD of 4.9333
    EVO 1 and 2s:
    1.090 (24/22) TR
    4.266 (64/15) FDR
    3.909 (43/11) RDR
    RDR x TR 1.090 (24/22) = 4.264 combined rear final drive
    TFD = 5.443
    EVO 3
    1.074 TR (29/27)
    4.200 (63/15) FRD
    3.909 (43/11) RDR
    RDR x TR = 4.199 combined rear final drive.
    TFD = 5.358
    The total final drive TFD, is the diff ratio (front or rear+transfer) multiplied by the 37/29 (1.276) primary reduction inside the gearbox that occurs before the diffs.
    Contrary to belief, converting one of these 4WD 'boxes to FWD will NOT change the final drive ratio, why the hell would it?
    "and yes an evo 2 gearbox and evo 3 rear diff would work together using either the evo 2 or gsr transfer case"
    My DSM:
    Street Build
    16g   manual
    Loading...
  16. keltalon
    3,277
    941
    Joined Jun 29, 2003
    These are all JDM part numbers for the Evo 1/2/3 transmissions (W5M33):
    3rd Gear Double Synchro MD747255
    4th Gear Double Synchro MD747255
    5th Gear Synchro MD745892
    Reverse Synchro MD746439
    1/2 Steel Shift Fork - MD749754
    3/4 Steel Shift Fork - MD749755
    3/4 Forged Shift Rail - MD749456
    Input Shaft (Evo 1) - MD747885
    Input Shaft (Evo 3) - MD747887
    1st Gear (Evo 1) 2.571 Gear Ratio - MD748095
    1st Gear (Evo 3) 2.750 Gear Ratio - MD743979
    2nd Gear(Evo 1) 1.600 Gear Ratio - MD744839
    Evo 1 2nd gear synchro - MD742614
    Evo 3 3rd Gear - MD747250
    3rd Gear Subgear - MD743314
    3rd/4th Hub/Slider - MD747378
    3rd/4th Gear Hub Springs - MD742441 x2
    3rd/4th Gear Hub Keys - MD742777 x3
    Evo 3 4th Gear - MD747376
    Evo 3 10% taller 5th Gear - MD743980
    Evo 3 5th Intermediate Gear - MD743319
    92-93 Evo 1 large single synchro 3rd Gear - MD743313
    92-93 Evo 1 large single synchro 4th Gear - MD743316
    93 Evo 1/2 shallow recess double synchro 3rd gear - MD746748
    93 Evo 1/2 shallow recess double synchro 4th gear - MD747252
    Evo 1 HD large diameter 3rd/4th hub and slider- MD747651
    Evo 1/2 HD small diameter double synchro 3rd/4th hub and slider - MD746716
    92-93 Evo 1 large diameter single synchro for 3rd or 4th gears - MD742536
    Evo 1 Reverse idler gear shift lever (MUST USE WITH EVO 1 Input Shaft and 1st/2nd gear assembly) - MD743281
    If you are going to use the Evo 3 double synchro 3rd/4th gearset with a USDM 3rd/4th hub and slider assembly (MD747646), you will need to machine the hub to clearance the double synchros, otherwise you will desroy it immediately. You should otherwise use the proper hub/slider assembly from Japan (MD747378).
    2G Synchros:
    1st gear MD745477 (original OEM)
    1st gear Shallow (uses 2 springs) MD742419
    2nd gear (double synchro) MD746435
    3rd gear (93-99) MD745479
    4th gear (93-99) MD745479
    5th gear (93-99) MD745892
    Reverse gear MD746439
    Input Shaft and Gearset Info:
    Input Shaft (1990.10-1999) MD747884
    Input Shaft Inner Tapered Roller Bearing MD732314
    Input Shaft Outer Tapered Roller Bearing MD726235
    3rd Gear Subgear MD741925
    3rd Gear Subgear Wave Washer MD723535
    3rd Gear Subgear Snap Ring MD724392
    3rd Gear Needle Bearing MD718033
    3rd Gear MD748582
    3rd/4th Gear Hub Springs MD742445 x 2
    3rd/4th Gear Hub Keys MD748663 x 3
    3rd/4th Hub/Slider MD749416
    4th Gear Needle Bearing MD749902
    4th Gear MD741838
    Input Shaft Snapring (1.4mm) MD723276
    Input Shaft Snapring (1.45mm) MD730889
    Input Shaft Snapring (1.5mm) MD723277
    Input Shaft Snapring (1.55mm) MD730890
    Input Shaft Snapring (1.6mm) MD723278
    Input Shaft Snapring (1.65mm) MD730891
    Input Shaft Snapring (1.7mm) MD723279
    Input Shaft Snapring (1.75mm) MD730892
    5th Gear Needle Bearing MD719137
    5th Gear MD743162
    5th/Rev Hub Springs MD742441 x 2
    5th/Rev Hub Keys MD742777 x 3
    5th/Rev Hub/Slider MD747654
    Input Shaft End Shaft Oil Seal MD739390
    Intermediate Shaft and Gearset Info:
    Intermediate Shaft (1991.5-1999) MD748830
    Intermediate Shaft Inner Bearing (ALL YEARS) MD726236
    Intermediate Shaft Outer Bearing (ALL YEARS) MD736638
    Intermediate Shaft Snapring (1.4mm) MD703779
    Intermediate Shaft Snapring (1.5mm) MD703780
    1st Gear Needle Bearing (1990-1999) MD737652
    1st Gear (DSM 3.083 Gear Ratio) MD743179
    1st/2nd Hub Springs MD742445 x 4 (use 4 springs with shallow synchro -- 2x springs per side, 3 springs with OEM synchro -- 2x springs on 2nd gear side/1x spring on 1st gear side)
    1st/2nd Hub Keys MD742775 x 3
    1st/2nd Hub/Slider MD749414
    2nd Gear Needle Bearing (1991-1999) MD737652
    2nd Gear MD748577
    5th Intermediate Gear (ALL YEARS) MD742581
    Output Shaft and Pinion Shaft:
    Output Shaft (23-spline 91.06-99) MD741190
    Output Pinion Shaft (91.06-99) MD742530
    Output Shaft needle Bearing MD718578
    Output Shaft Inner Tapered Roller Bearing MD718322
    Output Shaft Outer Tapered Roller Bearing MD727861
    Center Differential:
    1990 FWD Turbo Differential Carrier (M/T Diff Case) Bearings: MD710663
    90-99 Center Differential Inner Tapered Roller Bearing MD727860
    90-99 Center Differential Outer Tapered Roller Bearing MD720623
    Center Differential Case 1991.5-1999 MD741919
    Center Diff Pinion Gear Kit + Spider Gears MD733338
    Center Differential Spider Gear Side Shims (x2) MD737658
    Center Differential Cover MD727551
    Center Differential Case Bolts MD727552
    1991-1999 Center Diff Oiling Washer 2.75-2.82 MD741405
    1991-1999 Center Diff Oiling Washer 2.67-2.74 MD741406
    1991-1999 Center Diff Oiling Washer 2.59-2.66 MD741407
    1991-1999 Center Diff Oiling Washer 2.51-2.58 MD741408
    1991-1999 Center Diff Oiling Washer 2.43-2.50 MD741409
    1991-1999 Center Diff Oiling Washer 2.33-2.42 MD741410
    1991-1999 Center Diff Oiling Washer 2.25-2.32 MD741411
    1991-1999 Center Diff Oiling Washer 2.17-2.24 MD741412
    1991-1999 Center Diff Oiling Washer 2.09-2.16 MD741413
    Pinion Gear Oiling Washer 1.17-1.24 MD724949
    Pinion Gear Oiling Washer 1.09-1.16 MD720677
    Pinion Gear Oiling Washer 1.01-1.08 MD720676
    Pinion Gear Oiling Washer 0.93-1.00 MD720678
    Pinion Gear Oiling Washer 0.83-0.92 MD720679
    Pinion Gear Oiling Washer 0.75-0.82 MD720680
    Pinion Gear Oiling Washer 0.67-0.74 MD724950
    Pinion Gear Oiling Washer 0.59-0.66 MD724974
    Front Differential:
    Front Differential Roller Bearings (x2) MD706566
    Front Differential Case MD763447
    Front Differential Gear Kit MD722127
    Front Differential Spider Gear Oiling Washers (x2) MN178197
    Front Differential Cross Shaft MB001106
    Front Differential Cross Shaft Roll Pin MN178199
    Front Differential Ring Gear 1991-1996 58-tooth MD748872
    Front Differential Ring Gear 1997-1999 57-tooth MD770499
    Front Differential Ring Gear Bolts (x8) MD040557
    Front Differential Shim Kit MB185340
    Shift Forks:
    1st/2nd Gear Shift Fork MD723439
    3rd/4th 1992.5-1999 Gear Shift Fork MD746854
    5th/Reverse Shift Fork w/ plastic shift pads MD748630
    Shift Shaft Assembly Parts:
    Gearshift Interlock Retainer Bolt MD717876
    Gearshift Interlock Retainer Bolt Gasket MD720602
    Shift Shaft Assembly (9405.2-1999) MD747904
    Shift Shaft Limiter Plate MD740179
    Shift Shaft Stopper Kit (w/ retainer spring) MD720248
    Shift Linkage Lever Assembly Parts:
    Inner and Outer Linkage Bushings MD719165
    Shift Linkage Lever (9405.2-1999) MD721253
    Inner Flat Washer MD713416
    Outer Flat Washer (95-99) MF450194
    Lock Washer MF450405
    End Nut MF430005
    Dust Cap MD713757
    Shift Selector Roll Pin (M5x22mm) MD705490
    Misc.:
    End Shaft Nut (x2) MD731948
    Plastic Shift Pad MD712919
    Roll Pins 5.2mm x 26mm (x3) MD701722
    Transmission Filter MD738053
    Input Shaft Seal MD741818
    Front Left Axle Seal MD719710
    Front Diff (Right Axle) Oil Seal MD707184
    Output Shaft Seal MD723202
    Throwout Bearing MD749998
    Throwout Bearing Retainer Spring MD706185
    Throwout Bearing Bellhousing Sleeve MD716349
    Clutch Fork MD770506
    Clutch Fork Pivot Ball MD719602
    Clutch Fork Boot MD718077
    Bell Housing Case MD739932
    Gear Cluster Case (8903.1-9208.1) MD726632
    Gear Cluster Case (9208.2-1999) MD744770
    Intermediate Case Section MD746412
    5th Gear Outer Cover (9105.3-1999) MD741184
    Short Outer Bolts (x9) MF241294
    Long Outer Bolts (x2) MD720558
    Transmission Case Bolts (x12) MF241288
    Black Plastic Intermediate Shaft Oil Guide MD726480
    Transmission Breather #1 (x2) MD711443
    Transmission Breather #2 MD721764
    Transmission Breather Bulb MD733296
    Bellhousing Dowels (x2) MD020260
    Transmission Case Dowels (x4) MF472405
    5th Gear Outer Cover Dowels (x2) MF472402
    Reverse Wave Spring MD744342
    Reverse Cone MD725928
    Reverse Cone Machine Screws (x3) MD736513
    Reverse Switch MD730979
    Reverse Switch Washer MF660035
    Reverse Lockout Bolt MD734488
    Reverse Lockout Bolt Washer MF660035
    Shift Rail Interlock Plunger MD720908
    Bellhousing bolts (2G): MF140471
    cont. MD740892
    cont. MF140266
    cont. MD706012
    cont. MF140021
    Viscous Coupler Detent Ball MF540008
    Viscous Coupler Snapring (1.5mm) MD720687
    Fill Plug MD701850
    Fill Plug Gasket Washer MF660036
    Drain Plug MD728088
    Drain Plug Gasket Washer MN130495
    Drain Plug Magnet MD955485
    Reverse Bracket Allen-Head Screw MD734702
    My DSM:
    Street Build
    16g   manual
    Loading...
  17. keltalon
    3,277
    941
    Joined Jun 29, 2003
    Thanks Paul I will be cracking this thing open real soon.
    My DSM:
    Street Build
    16g   manual
    Loading...
  18. keltalon
    3,277
    941
    Joined Jun 29, 2003
    yeah this transmission has the gear ratio that I need for the 1/2 mile event :D
    My DSM:
    Street Build
    16g   manual
    Loading...
  19. iugrad92turbo
    iugrad92turbo Proven Member
    10,278
    305
    Joined May 22, 2007
    Kalamazoo, Michigan
    Good luck man with everything at the track.
    Loading...
  20. TSi-Rocket
    TSi-Rocket Proven Member
    157
    33
    Joined Jul 12, 2003
    Bryan, Ohio
    Kel I have an evo 1 trans in one of my cars. I thought it was stock until the center diff locked up on the interstate on my way to the shootout last year. It had the 4.26:1 front diff ratio. I was told by the seller it had a gvr4 first gear. The issue with these transmissions is you can no longer get the input shaft so when its toasted the whole transmission is done for.
    My evo 1 is WQNK non lsd. I really hope your center diff is in good shape. There are 3 different style center diffs. 1). 92-99 with a single tab for the lower oiling washer, 2) 90 which has a different oiling washer design and a different outer gear profile, 3) early 91 which has the updated oiling washer (92+) but shares the gear profile with the 90(and my evo 1). I built an extra center diff from a 92+ bc the evo CTD looked like the 92+. When I was assembling the transmission all excited I hit a road block with the CTD bc the gear profile was wrong. I should have welded my extra early 91 ctd (its not rebuild able) but I pulled a mint ctd out of a 90 trans and used it. Tim told me the evo 1 with the 90 ctd gear cut were the early models so your ctd should be 92+. Just trying to give a heads up.
    My DSM:
    1992 Eagle Talon TSi
    Street Build
    14b   manual
    1992 Eagle Talon TSi AWD
    Street Build
    14b   manual
    Loading...
  21. pimpy rider
    pimpy rider Proven Member
    123
    18
    Joined Mar 27, 2009
    Saskatoon,
    do you have the passenger side axle for the lsd?
    the lsd axle is about 1/2 inch longer.
    transfer cases are the same, just a 91-96 case for the evo 1-2 and 97-99 for the e3
    or just swap the 90 shaft and use the 90 t case if you have one
    your going to swap in dsm final drive im assuming?
    i did this exact swap 5 yrs ago
    evo 1 trans no lsd tho
    that tall first was incredible!
    but i was in a colt with 23 inch tires and 2550 lbs
    might be a bit tall for a 3000 lb car
  22. pimpy rider
    123
    18
    Joined Mar 27, 2009
    Saskatoon,
    i have an evo3 lsd box in my colt and its the best mod ever. ive only gone down the strip ten times or so with it but i have yet to miss a shift
    trans is usually the last thing guys upgrade but to me its the most important mod.
    it was always so frustrating missing shifts at the track
    crunch!
    haha
    even the evo first gear makes a huuuge difference because it makes a smaller gap to second as well
  23. TSi-Rocket
    157
    33
    Joined Jul 12, 2003
    Bryan, Ohio
    The 2.57 first gear rules in a 1g. I can actually cruise parking lots in first. Its really annoying in parking lots with a standard dsm trans... Run first at 4k rpm or chug around in second. The 8% taller 5 sucks at 55mph tho, its not enough rpm and lugs the motor and I find myself downshifting for hills (8.5:1 cr with 272/272 14b) once you get above 60mph it rocks and its awesome at 70.
    My DSM:
    Street Build
    14b   manual
    Street Build
    14b   manual
    Loading...
  24. donniekak
    donniekak DSM Wiseman
    4,307
    647
    Joined Mar 23, 2008
    Surprise, Arizona
    If your trans has the large synchro 3-4 you'll want to toss those parts in the trash, as the large synchro 3-4 uses the 2g style hub/slider that explodes over about 400ft/lbs.
    My DSM:
    1991 Eagle Talon TSi AWD
    Street Build
      manual
    Loading...
  25. keltalon
    3,277
    941
    Joined Jun 29, 2003
    Thanks guys. this transmission has been in this car for 9 years and was driven from Arizona to Atlanta according to the previous owner he had no idea about it being a evo 1 unit until I texted him LOL. I only pulled it out of the car to change the clutch but decided to go ahead and tear it apart to replace the sychros and have the gears wpc treated in preparation for the 800hp engine. I will try and tear it down today. Thanks for all the heads up for sure!
    My DSM:
    Street Build
    16g   manual
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrications OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports Tire Rack VR Speed Factory White Shed Speed
