gofer
Moderator
- 8,152
- 1,444
- Feb 18, 2006
South Gilbert,
Arizona
The ISC isn't connected through sensor ground, I pulled up the Mitsu EL and looked at the 2.0l turbo diagram. Not sure why my online ARRC manual of 1g EL diagrams are jacked up, they were only pulling up 1.8l N/T even after I selected GSX too. You were also right about the MAF harness, it was across pin 6, again those were pin outs for the 1.8l.
Plug the ECU connector in and check continuity from any of the above sensor grounds to chassis ground, post your results.
