9!'clipseDOHC
Moderator
- 4,906
- 452
- Aug 24, 2003
El Paso,
Texas
My check engine light has been on ever since the first time I started up my car after my turbo swap which was about 10 months ago (or less). I just installed ECMlink and when I looked at my DTC's it was showing:
- 0042 - Fuel pump circuit malfunction
- 0025 - Barometric pressure circuit malfunction
I cleared the codes and then checked again and the 0042 code popped right back up. Any ideas on what this could be? The car has been running great (pre-ecmlink, since the install i've just been working on figuring out 'link and adjusting my idle[THANKS GOFER!!!])
My fuel pump is a Walbro 255 lph pump which I installed back in 2005. The fuel pump was rewired at the same time as the turbo swap (early 2010). The car does lose all fuel pressure when I shut it off and I have to crank it for several seconds before it will start if it has sat for more then a few hours. Once it's running the fuel pump seems to be working fine.
That's all the info I've got for now. Thanks!
