Engine Removal without Transmission
Posted by eltoshan, Nov 7, 2009
Maintenance & Repairs - Oil choices, timing belt, setting timing, CV boot replacement, alternator servicing, fuse/relay checks, and other basic maintenance, repair and diagnosis discussions.
  1. eltoshan
    eltoshan Proven Member
    DSM Profiles:
    Oct 26, 2009
    50
    Pittsburgh, Pennsylvania
    I'm in the process of taking the block out on a 2G to inspect it, but there is really no need for me to take the transmission out. The engine removal tutorial on vfaq takes the transmission out with the engine. Is there a way to remove the engine without taking out the transmission?
    #1
  2. 91talontsi0324
    91talontsi0324 Proven Member
    Dec 18, 2008
    96
    pittsburgh, Pennsylvania
    You can take it out without the transmission, but its probably going to be more of a headache than its worth. It's a lot easier to just take them both out together and disassemble the trans from the block when they're both out. It just saves you from having to go under the car and unbolt the transmission from the block. Is the car fwd or awd?
    #2
  3. eltoshan
    DSM Profiles:
    Oct 26, 2009
    50
    It's an 5sp AWD. Unbolting the transmission sounds a little easier than taking out all of the axles and transfer case though.
    #3
  4. 91talontsi0324
    Dec 18, 2008
    96
    I think i misunderstood what you meant. You want to leave the transmission in the car and pull the block correct? Not remove the trans first and then the block?
    #4
  5. snowborder714
    snowborder714 Moderator
    DSM Profiles:
    Oct 15, 2006
    11,883
    168
    Downingtown, Pennsylvania
    Remember you still have to get the bell housing over the flywheel and pressure plate. I'd say to pull the transmission with the engine as one unit. You'll just make more work for yourself by trying to leave it in the car.
    #5
  6. jrohner
    jrohner Proven Member
    DSM Profiles:
    Sep 25, 2004
    2,551
    8
    Willmar, Minnesota
    There is not enough room; you can only do it that way if it's an automatic.
    #6
  7. eltoshan
    DSM Profiles:
    Oct 26, 2009
    50
    Damn, I guess I just gotta suck it up and pull the whole thing then.
    It just seems kinda ridiculous that you have to remove the transfer case and drive axles to pull out the engine.
    #7
  8. BullseyeGSX
    BullseyeGSX Probationary Member
    DSM Profiles:
    Sep 4, 2009
    21
    Reisterstown, Maryland
    AWD Is your friend just remember if you get mad don't take it out on the car !!!
    #8
  9. boosteclipse
    boosteclipse Proven Member
    DSM Profiles:
    Jan 25, 2009
    127
    Newark, Arkansas
    Pull them together, it is a pia, but the only way.
    #9
  10. KevinRR
    KevinRR Proven Member
    Sep 11, 2007
    215
    Milwaukee, Wisconsin
    Just take out the engine and trans out together, it would be less of a headache trying to pull the engine from the tran while it in the car.
    #10
  11. Dsmj89
    Dsmj89 Proven Member
    Nov 11, 2008
    2,150
    9
    Miami, Florida
    I also agree on taking out both engine/tranny altogether. Much much easier.
    #11
  12. DSMizzy
    DSMizzy Probationary Member
    Sep 10, 2009
    14
    Jacksonville, Florida
    I just pulled mine out its a Fwd but i pulled motor and trans than installed motor then trans puting it back in did not seem to be that big of a problem.
    #12
  13. SharonTampons
    SharonTampons Probationary Member
    Nov 15, 2005
    27
    orlando, Florida
    That is the nature of most transverse mounted platforms. :thumb:
    If you can get the car high enough, I find that it is easiest to drop the engine and trans together through the bottom, onto a piece of plywood or a few layers of cardboard. (works especially well when using a lift) You don't even have to pull the driveshaft. Just unbolt the first carrier bearing and it should slide out when you pull the motor. The CV shafts should only take you 30minutes extra.
    Remove the radiator with fans to give yourself some working room and just take your time. Replace the timing belt, water pump and all associated parts when you have it out.
    #13
  14. spdtuned
    spdtuned Proven Member
    Mar 14, 2008
    47
    Orange County, California
    To remove the axles You can just unbolt the upper a-arm from the strut mount plate. This saves you from needing to mess with the ball joints ;)
    #14
  15. ak-dsm
    ak-dsm Probationary Member
    Jun 30, 2008
    15
    anchorage, Alaska
    I've done it twice already but again it's kinda a pita you gotta put a steep angle on the motor done the same putting it in also. The last time I did when I went to put it togeather I just had the complete short block go in then threw the head on after it was in, also I left the oil pan off as well
    but this was on a 1g awd
    #15
  16. SharonTampons
    Nov 15, 2005
    27
    orlando, Florida
    Thats why I find it easiest to drop through the bottom for removal and installation. The car has to be pretty low initially to allow enough space for the boom of the cherry picker to lower the engine and trans down onto the wood. Then I use the cherry picker and chain to lift the front of the car, and raise the jack stands as high as they will go. Then slide the motor and trans out, it should clear the bumper permitting that you don't have tiny jack stands. I just remove the cross members and lower motor mounts/brackets and loosen the side mounts, and the it drops straight down without any interference (if you have a lift, position a tire or two under the oil pan and transmission, then lower the car until they are barely touching. Un-bolt everything, then raise the car straight up)
    I find that this technique is most helpful on DSMs that still have all of the accessories (AC, PS, Cruise control, Battery tray, etc..) with a gutted, trim engine bay this technique is not really beneficial.
    #16
  17. 9!'clipseDOHC
    9!'clipseDOHC Moderator
    DSM Profiles:
    Aug 24, 2003
    3,448
    153
    El Paso, Texas
    I was just reading through this thread and everyone is saying its a pia but most are AWD. Has anyone with a 1g FWD 5 speed, pulled the engine out, without the transmission?
    I've pulled the engine out a few times but always with the transmission. I would rather just leave the transmission in this time rather then removing the axles and stuff. Has anyone done it?
    #17
  18. 90moneypit
    90moneypit Proven Member
    Mar 2, 2010
    254
    treefall, Washington
    If you think it's a PITA to remove the transmission with the engine, try re-installing the engine onto the transmission with it still in the car! You COULD take the alignment dowels out but they're there for a reason. You know like, making sure it shifts into all 6 gears (yes Reverse is a gear) without grinding off half the teeth and that's if you get it into gear at all. It's hard enough getting the two back together correctly with them both outside the car...
    #18
  19. jonnyz
    jonnyz Probationary Member
    DSM Profiles:
    Jan 12, 2010
    5
    Santa Rosa, California
    I would also recomend that when you are removing the engine/trans together to remove the transfer case first...It is only five bolts and makes it a heck of a lot easier to get the engine out of the car. You won't have to angle the engine to get it up and out.
    #19
  20. 9!'clipseDOHC
    DSM Profiles:
    Aug 24, 2003
    3,448
    153
    El Paso, Texas
    Well I'm FWD so that's not an issue. I went ahead a pulled it out with the trans.
    [​IMG]
    #20
  21. dsm8883
    dsm8883 Proven Member
    Dec 19, 2004
    206
    gainsville, Florida
    The huge thing to remember here is that on 2g's 3 out of 4 mounts are on the trans. i have tried leaving the trans in on 2gs before but it is a 1000 times simpler and faster to pull them as a unit and split them out of the car.
    #21
  22. Coreyred95
    Coreyred95 Proven Member
    Mar 25, 2010
    160
    Minneapolis, Minnesota
    It is also best to drop the engine and tranny together from the bottom on a 2g N/T, in case anyone is wondering.
    #22
  23. Aproductions
    Aproductions Proven Member
    DSM Profiles:
    Aug 11, 2009
    1,856
    12
    Bethlehem, Pennsylvania
    I pulled my engine out without touching the tranny.
    take the head off and then when it is just the block, take the crank pulley off and you can move the block over to the rigth alittle and clear the pressure plate, then pull it out.
    its a pain in the ass though, my father helped me.
    #23
  24. extremeatheist
    extremeatheist Proven Member
    Apr 12, 2010
    36
    wilson, North_Carolina
    I was wondering about that.
    #24
  25. camron_m
    camron_m Probationary Member
    Jun 10, 2009
    11
    Lexington, Kentucky
    I have removed 2G fwd and 1G awd without removing trans its not that hard. If you take the mounts off of the trans on the fwd and support it with a jack you can get enough movement to clear the flywheel out of the cv axles. On the awd you have to remove the transfer assembly housing (5 bolts and d/s) from the transmission an you should be able to pull it separate.
    #25
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
