Engine goes very lean when stepping on throttle.
Brad Bell
192
5
Aug 15, 2014
Levant, Maine
My turbo 420a GS has started having this problem where if the rpms are low and I step on the gas (idle, or cruising), the engine goes extremely lean for a second and the car hesitates bad, after the rpms get around 2k it smooths out. The most recent mod I made on my engine is larger injectors running at really low fuel pressure for it to idle. I'm thinking this is either bad spark plugs (been about a year sense I replaced them) or its my throttle position sensor.
Thanks guys.
What are you using to tune since you've add many mods? If I recall from your past posts you have not addressed a ECU tuning method & have been fighting issues with compounded bandaid solutions. Also I believe other turbo 420A members have advised the need to pony up & referenced Megasquirt. You are going to have to pay to play.
Well I haven't had this problem before, even with the larger injectors, so I figured it wasn't an ecu problem. In general if an engine does this what I described above what are some possible causes?
If you have no mechanical issues this would be a tuning problem. This sound like a tuning problem to me. You're asking an ECU to compensate for driveabilty conditions which are outside the OEM's ability to compensate for & bandaids (nor piggybacks) will not get you there. Hopefully some turbo 420A guy with actual first hand experience will chime in with better more specific advise. I'm a 4g63 guy running a full standalone because the bandaids nor piggybacks could compensate enough for my driveability issues after I added all my mods.
well you beat me to the exact reply i was typing out LOL
I forgot to add "Good Luck" for OP. @Brad Bell. "Good Luck"
Thank you Mello, I understand a standalone system like MS is the way to go, I'm planning on getting one next summer. Just trying to push the stock ecu to it's limits with my piggypack mods. I know there are some expert 420a turbo guru's out there, just hard to come by these days being the 4g63 is so popular.
You have a bigger turbo, bigger injectors, bigger fuel pump, and cooler air than stock (FMIC). You needed a MS a while ago. Not sure what piggybacks you are using, but I doubt it is right.
