1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
Engine Bogs
Posted by PIGNOSE, Jun 25, 2018
Please Support STM Tuned
  1. PIGNOSE
    PIGNOSE Probationary Member
    11
    Joined Apr 22, 2018
    Queretaro, Central America
    Hello
    My stock 2G GST does not pull hard after 4500rpm in all the gears, the engine feels like its running without any boost after this rpm
    but... the problem doesn't appear while the car is in neutral at WOT
    I've recently replaced:
    -spark plugs cables
    -spark plugs
    -knock sensor
    -gasoline filter
    the car is running at 10psi
    i've checked for boost leaks and cleaned the injectors
    thank you for reading
    Log in/Register to remove ads
    Featured Products from our Supporting Vendors
  2. Vegas smith
    Vegas smith Proven Member
    2,120
    920
    Joined Dec 2, 2002
    Houston, Texas
    Do a compression test on the engine. Any check engine lights?
    My DSM:
    1993 Eagle Talon TSi AWD
    Street Build
    GT30   manual
    1992 Eagle Talon TSi AWD (sold)
    16g   manual
    Loading...
    PIGNOSE likes this.
  3. PIGNOSE
    11
    Joined Apr 22, 2018
    i did a compression test when i bought the car, the results were 120psi all across
    yes the check light engine is on
    went to autozone and pulled out one code p0130
    you think the oxygen sensor is the cause?
  4. Mello
    Mello Proven Member
    685
    117
    Joined Jul 4, 2003
    Albuquerque, New Mexico
    Yes I think an O2 sensor could cause this problem.
  5. Vegas smith
    2,120
    920
    Joined Dec 2, 2002
    Houston, Texas
    I agree^^
    My DSM:
    Street Build
    GT30   manual
    16g   manual
    Loading...
  6. PIGNOSE
    11
    Joined Apr 22, 2018
    i just replaced the oxygen sensor and erased the code
    the problem still there
    any other ideas???
    btw im getting great gas milage now..
  7. Mello
    Mello Proven Member
    685
    117
    Joined Jul 4, 2003
    You said you replaced the spark plugs. What Brand plugs did you put in?
  8. PIGNOSE
    11
    Joined Apr 22, 2018
    replaced them with NGK BPR6ES gapped at .030
  9. 802gst
    802gst Proven Member
    52
    26
    Joined Feb 12, 2017
    St.albans, Vermont
    try dropping that gap down to .26-.28, might not be the issue but this has happened to my gst before she doesn't like .30
    My DSM:
    1998 Eagle Talon TSi AWD
    Street Build
    16g   manual
    Loading...
  10. adrian2627
    adrian2627 Proven Member
    119
    4
    Joined Jul 13, 2005
    Hattiesburg, Mississippi
    BLT done?
    My DSM:
    Loading...
  11. 1990TSIAWDTALON
    1990TSIAWDTALON Moderator
    3,130
    995
    Joined Nov 14, 2013
    Independence, Kansas
    Factory is .028.
    I run mine much tighter but under much more boost.
    My DSM:
    Street Build
    14b   automatic
    1990 Eagle Talon TSi AWD
    13.620 @ 108.460 MPH
    13.612 @ 107.760 MPH
    Loading...
  12. chrysler kid
    chrysler kid Proven Member
    1,555
    368
    Joined Dec 20, 2002
    Mckinney, Texas
    The T25 sucks but it shouldn't fall at 4500, more like 5500
    The T25 minimum boost off the wastegate actuator is 12psi. So you have a boost leak or the wastegate actuator is messed up
    Loading...
  13. PIGNOSE
    11
    Joined Apr 22, 2018
    done
    thanks bro
    yes sir, two times just to make sure
    boost doesn't creep or drop at 4500rpm or after
  14. adrian2627
    119
    4
    Joined Jul 13, 2005
    How's the basic maintenance? is base timing set? any CEL flashing from 4500 on? fuel pump still good? FPR still good? fuel filter good?
    My DSM:
    Loading...
  15. PIGNOSE
    11
    Joined Apr 22, 2018
    As far a basic maintenance all filters, liquids and plugs have been replaced. Checked the base timing and all marks line up.
    I also checked the FPR with a vacuum gun and hooked up a fuel pressure gauge to the fuel line, everything looks in range on idle and under boost (boost is set a 10psi)
    I don't now what CEL flashing is...
    the problem persist
  16. adrian2627
    119
    4
    Joined Jul 13, 2005
    stupid question but...do you thing the clutch is slipping after 4500?
    My DSM:
    Loading...
  17. PIGNOSE
    11
    Joined Apr 22, 2018
    mmm i believe the clutch is in good
    The car has torque steer while shifting through the gears from 1st to 2nd gear
  18. adrian2627
    119
    4
    Joined Jul 13, 2005
    Do you have any way to log your ecu? kinda hard to play guessing game without some sort of data in front of us.
    My DSM:
    Loading...
  19. rEclipserGST
    rEclipserGST Proven Member
    1,395
    14
    Joined Nov 17, 2007
    G-City, Ohio
    What did you do the BLT to?
    My DSM:
    1995 Eagle Talon TSi AWD
    Street Build
    187 whp   200 lb/ft
    1995 Eagle Talon TSi AWD (sold)
    13.583 @ 108.440 MPH
    Loading...
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Miller Import Parts Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
