kiddsm95
- 154
- 0
- Mar 23, 2007
Ann Arbor,
Michigan
I initially thought that my MPI relay was going bad, but when I tested it I've verified that pin #6 (I think) is at 12V with the ignition off, then it is going low (0.86V with the ignition on...This is what it's supposed to do I believe. The MPI relay is sending power to pins 12 & 25, so I think I can claim that the relay is good.
The problem is that I'm not getting power on pins 71 & 82 with the ignition on or off. I believe that these pins are supposed to be "hot" all the time??? Looking at the schematic it points to the ignition switch, but if my ignition switch was bad wouldn't that mean that my dash lights shouldn't be working?
The car is getting fuel and spark, but I just can't get it to start. Is it the ignition switch or are there other components that would power pins 71 & 82?
