ZDA1728
- 95
- 0
- Dec 13, 2012
Chicago,
Illinois
Is it possible to achieve true anti lag with ecuflash? Not just 2 step?
Note: This feature currently requires accessing the site using the built-in Safari browser.
From an actual ecuflash user.... Yes, you can use actual anti lag, with fuel enrichment adjustable afr, and timing control, mph, etc... It's fantastic and sounds like gunshots. It can do some damage with the obvious heat from usage, but just don't hit the antilag every red light and you should be good, plus also keep your rev limiter for it lower and same for the timing/fuel control. It does wonders even in moderation. 2-step rev limiter is mehIs it possible to achieve true anti lag with ecuflash? Not just 2 step?
Fixed sorry to be that guyIf you learn to properly slip a clutch it won't matter how much boost your 2 step can build. My 2 step builds 5 psi and by 5 mph my car can see 25+PSI from loading the engine with the clutch, but that's not relevant to the thread title. Just research antilag quite a bit before messing with it.
