razza
- 1
- Feb 12, 2003
Christchurch,
New_Zealand
Hi all,
My car is currently in with a workshop to have the dyno tune completed. I am unsure about how much boost I should ask the tuner to use. Obviously o2 readings and knock will be a limit at some point. It will be running on pump gas (equivilant to 93/94 in the USA). I would appreciate advice from members on here with direct experience.
Engine setup is:
9.0:1 forged pistons
Aftermarket rods
ARP head studs
Cometic head gasket
ID1000 injectors
300lph fuel pump
Fuelab fuel filter and adjustable fuel pressure regulator
Forced Performance GT35R with 0.68 exhaust housing
Larger intercooler w/ 2.5" intercooler piping & Tial BOV
Degree'd Kelford 272 cams with dual valve springs
3" Exhaust
Standalong ECU
Cheers!
Ryan
Engine setup is:
Aftermarket rods
ARP head studs
Cometic head gasket
ID1000 injectors
300lph fuel pump
3" Exhaust
Standalong ECU
Cheers!
Ryan
