brads
DSM Wiseman
- 856
- 109
- Oct 24, 2002
Alta Loma,
California
The tech mentioned in that old thread(Larry) hasn't worked there in a few years. Scott should be able to take care of it. One thing you COULD do to show that it is in the adapter or in the ARC-2 itself, would be to depin and swap the wires at the 3 pin connectors on the ARC-2 harness. If you swap the 2 wires that are for the 2 different coils on both the connector going to the coil, and the one going to the harness, then look to see which cylinders are misfiring. If it is the same cylinders still, that tells you the problem is somewhere else in your system. But if it swaps to the other cylinder pair, that pretty well proves that it is in the ARC-2/ wiring.
