1. This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn More.
  2. Trouble Logging In or Staying Logged In?
    CLEAR YOUR BROWSER COOKIES! More info about this can be found here. If you still have trouble after clearing your browser's cookies and cache, reply to that thread and tell us what browser you're using and what device you're using.
1G Dual piston caliper bolt
Posted by tk106, Jan 12, 2019 at 11:33 AM
Please Support JNZ Tuning
  1. tk106
    tk106 Proven Member
    652
    70
    Joined Sep 11, 2017
    Cincinnati, Ohio
    Hey guys! One of my caliper bolts broke off in the bracket. Luckily I was able to get it out by heating the backside. Be careful because this thing shot out like a bullet and I can’t find where it went. Any hooo I need to know the part number for this bolt. From what I’ve read, seems like all the hardware are the same in the dual piston set up but I’m not 100. Does anyone know the part number for this bolt.
    Thanks Tony
    B6C49F2A-5494-4581-A056-70F4315C6907.jpeg 164D5546-667F-409C-945E-391DB8EB4F25.jpeg
    Log in/Register to remove ads
    1992 Eagle Talon TSi AWD
    Street Build
    16g   manual
    Loading...
    Featured Products from our Supporting Vendors
  2. DSMPT
    DSMPT Proven Member
    183
    29
    Joined Jun 12, 2014
    Sonora Mexico, Arizona
    Front Guide Pin, M15 / MB618227
    Front Lock Pin, M15 / MB618228 (This is the one you broke)
    1998 Mitsubishi Eclipse GSX
    Street Build
    16g   automatic
    1990 Mitsubishi Eclipse GSX
    Drag Race Build
    GT40   manual
    Loading...
  3. tk106
    tk106 Proven Member
    652
    70
    Joined Sep 11, 2017
    Cincinnati, Ohio
    Thanks DsmPT! I appreciate it!!
    Street Build
    16g   manual
    Loading...
  4. Mello
    Mello Proven Member
    700
    122
    Joined Jul 4, 2003
    Albuquerque, New Mexico
    I would just get these from Rockauto. They're under brakes>guide pins. You broke the bolt that has the bushing. If you can't find the lost end & retrieve the bushing you should also buy some new bushings too, again from Rockauto.
  5. tk106
    tk106 Proven Member
    652
    70
    Joined Sep 11, 2017
    Cincinnati, Ohio
    Thanks Mello! I actually found it. When you say bushing, is that the rubber tip that slides in on the end? Also, do you search under 95 and up gsx? Thanks!
    Street Build
    16g   manual
    Loading...
  6. tk106
    tk106 Proven Member
    652
    70
    Joined Sep 11, 2017
    Cincinnati, Ohio
    Found it. Just don’t know if mine are off of a 95+ gsx
    Street Build
    16g   manual
    Loading...
  7. tk106
    tk106 Proven Member
    652
    70
    Joined Sep 11, 2017
    Cincinnati, Ohio
    Does the bolt with the rubber sleeve go on top or bottom? I’d guess it goes on top but it was flipped on the other side and I just want to make sure.
    Thanks!!
    Street Build
    16g   manual
    Loading...
  8. tk106
    tk106 Proven Member
    652
    70
    Joined Sep 11, 2017
    Cincinnati, Ohio
    Found it. Rubber bushing goes on top.
    Thanks for your help!!
    Street Build
    16g   manual
    Loading...
Share This Page
Loading...
Log in/Register to remove this ad
Ace Race Parts Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions JNZ Tuning Kiggly Racing Morrison Fabrications OHM Racing RockAuto SouthBay Fuel Injectors STM Tuned Tire Rack VR Speed Factory White Shed Speed
