DTC P0335 Crankshaft position sensor circuit malfunction
Posted by UofACATS, Mar 15, 2008
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support JNZ Tuning
  1. UofACATS
    UofACATS Proven Member
    DSM Profiles:
    May 11, 2004
    649
    13
    Tucson, Arizona
    DTC P0335 Crankshaft position sensor circuit malfunction.
    There are actually two P0335 codes, one is for crankshaft position sensor, one for crankshaft position sensor circuit. The second is my code. I've removed emissions equipment on my vehicle if that's revelant, the Chiltons manual seems to suggest it is.
    Any insight as to what causes this DTC would be appreciated.
    :dsm:
    (Threads all pertaining to my specific problem, unfortunately none are resolved.)
    http://www.dsmtuners.com/forums/search.php?searchid=4278360
    #1
  2. luv2rallye
    luv2rallye DSM Wiseman
    DSM Profiles:
    Jun 7, 2003
    7,237
    394
    Minneapolis, Minnesota
    #2
  3. UofACATS
    DSM Profiles:
    May 11, 2004
    649
    13
    Tucson, Arizona
    Thank you!!!!
    I do believe I have a CPS on my spare head. I also have a spare ECU. I'll do a bit of testing first, however.
    #3
  4. UofACATS
    DSM Profiles:
    May 11, 2004
    649
    13
    Tucson, Arizona
    (Well, the sensor on the head is the cam position sensor.)
    I'm in the process of removing the lower timing cover to access the crank position sensor (which sucks!) I'm goint to buy some speciality wrenches and probably make a tool this week.
    Would this particular DTC (P0335) cause a no-start? I assume it would if the position of the crank is unknown to the ECU.
    #4
  5. luv2rallye
    DSM Profiles:
    Jun 7, 2003
    7,237
    394
    #5
  6. UofACATS
    DSM Profiles:
    May 11, 2004
    649
    13
    Tucson, Arizona
    I tested the crank position sensor. As well as I could anyway, since my car does not start the idle test is obviously not possible. While cranking, the CPS sensor shows no voltage where it should show 0.4-4.0. I tested all three pins too just to be certian. Now I call Mitsubishi.
    #6
  7. UofACATS
    DSM Profiles:
    May 11, 2004
    649
    13
    Tucson, Arizona
    Just a follow-up. I replaced the CPS and the code is gone. My car starts too, although I'm battling other issues at the moment.
    #7
  8. DML01Gs
    DML01Gs Probationary Member
    Dec 31, 2015
    MUNCIE, Indiana
    #8
  9. luv2rallye
    DSM Profiles:
    Jun 7, 2003
    7,237
    394
    #9
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
