DTC 0100 Volume Air Flow Circuit Malfunction
Posted by unisonicz, Oct 2, 2010
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support ExtremePSI
  1. unisonicz
    unisonicz Proven Member
    DSM Profiles:
    Sep 23, 2010
    113
    Clarksville, Tennessee
    Hi, I am getting DTC0100 Volume Air Flow Circuit Malfunction. I have done some searching and can not figure out what it goes to. The only thing I have seen is my MAF is bad?
    #1
  2. Ninharu
    Ninharu Proven Member
    DSM Profiles:
    Jun 9, 2004
    71
    Edmonton, AB_Canada
    Same thing happened to me. There are a few things to check. First make sure your maf is actually plugged in and there are no loose wires. For me it was simple the wire on pin 90 on my ECU was worn down and basically had an intermittent contact. All I had to do is cut, solder and heat shrink the wire and my problem was solved. I
    #2
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
