driverccc
- 86
- 0
- Mar 5, 2012
north shore,
California
4G63T - DSM PART OUT! Running motor
$2,800 for the whole car
I have here a 1996 Mitsubishi mirage FWD 4g63t 6bolt swap. (in car running)
Comeplete! 1990 1g 4g63t - came out of a awd eclipse. Rebuilt head with 5k miles with all new gaskets! stock bottom end with 140k miles (150psi all cylinders)good compression. 2g 450cc injectors, oil pump delete, 2g elbow, the following parts only have 5k miles on them as well such as - timing belt & kit, shaft belt, water pump, rebuilt mhi 16g turbo, New evo lll exhaust housing(600miles), new spark plugs new alternator.. comes with both manifolds with new gaskets comes with everything except for wiring harness or ECU...(will throw in 2g maf, New copper exhaust manifold gasket as well)
Complete! 1996 Mitsubishi mirage Clean title rolling shell (if motor sales) - Rolling shell is 4g63t ready. wiring harness and ECU will be ready. Rolling shell comes with mirage transmission no grinds, no pop outs with stage 4clutch(will come with fly wheels pressure plate, Custom intercooler setup, New Driver & passenger side axles + seals, New passenger side HUB and wheel bearing + seals, New 4 KYB GR-2 shocks, 2in lowering springs, New apexi turbo timer, Stereo custom speakers, Boost gauge, 13inch stockies, HKS BOV, Slim fan, NEW driver side & passenger side inner/outter tie rods, 255 WALBRO fuel pump, led license plate lights, stock headlights, body i rate it at 7/10 and interior 7/10 as well...sleeper look!
NOT IN RUSH TO SALE SINCE I USE THIS CAR STILL AT TIMES.
