drove car with no oil! replace head?
Posted by 97dsmGST, Apr 7, 2008
Cylinder Head & Short Block - 4G63 cams, valvetrain, pistons, rods, stroker kits, 6-bolt swaps, hybrids, etc. Read this Forum's Strict Guidelines.
Please Support Boostin Performance
  1. 97dsmGST
    97dsmGST Proven Member
    Apr 28, 2005
    13
    Jacksonville, Florida
    i have a 1997 gs-t and i carelessly drove it with no oil :beatentodeath:. it started making a ticking, clicking sound and eventually grew louder and was not drivable. from reading around i understand that i probably have bent valves, damaged pistons, and off timing.
    so the question is: will i be able to fix the car just by replacing the whole head? are there any other components damaged? and what will it take to fix this problem? :confused:
    #1
  2. schoffs4
    schoffs4 Proven Member
    May 5, 2006
    77
    Derry, New_Hampshire
    Is it seized? I would worry about the crank , rod, bearings first. Pull your oil pan down and take some rod caps off. No oil will not mess with valve timing or bend valves, check the low end first.
    #2
  3. 97dsmGST
    Apr 28, 2005
    13
    what do you mean by seized :confused:? i thought it would be around the head because i thought the clicking or ticking noise was from the piston hitting the valves or something. hmm, guess not. thanks for the heads up. will check on it when i get the chance
    #3
  4. kahl23
    kahl23 Proven Member
    DSM Profiles:
    May 10, 2004
    946
    9
    Wellesley, Massachusetts
    Timing shouldn't be affected, its all controlled by the timing belt, not the oil. Your bearings, on the other hand, have a high probability of being toast, which could be causing the noise you're hearing.
    #4
  5. VTRICCO
    VTRICCO Proven Member
    DSM Profiles:
    Dec 28, 2003
    227
    Ridgewood Queens, New_York
    aggred. your on the fast track to throwing a rod
    #5
  6. 97dsmGST
    Apr 28, 2005
    13
    what should be recommended to fix this? should i might as well buy a new engine ? :(
    #6
  7. chavez408
    chavez408 Proven Member
    Dec 13, 2003
    589
    Bay Area, California
    How did you manage to run with no oil?
    Did you pop he dipstick and it read zero? If so, most of the time that does not mean the car doesn't have no oil in it. Sometimes there is like 2 quarts in there even if the dipstick reads zero.
    #7
  8. 97dsmGST
    Apr 28, 2005
    13
    im burning oil somewhere because the exhaust emits bluish smoke, and im pretty sure its from the head gasket or valve cover gasket. i would have to put in oil from time to time to compensate for the loss, as indicated on the dipstick. well the light for the oil is always on and off so i never pay attention to it. i guess i just ran in too far without adding more oil and it just burned up all the oil :cry:
    #8
  9. absolute_DSM
    absolute_DSM Proven Member
    Jan 29, 2006
    1,552
    6
    Boise, Idaho
    What do you mean by not drivable? If it physically stopped and you cant start it, you probably seized the engine. Try and turn the crank with a ratchet.
    #9
  10. 97dsmGST
    Apr 28, 2005
    13
    it didn't physically stop, but the clicking or ticking noise became so loud and unbearable that i coulnd't drive it as is. i was driving it home from work and the further i drove the worse it got.
    #10
  11. kahl23
    DSM Profiles:
    May 10, 2004
    946
    9
    If you're burning oil in the exhaust, then it probably isn't an issue with the valve cover gasket, as that would just be a leak that might burn off on the manifold or some other part of the engine bay. Headgasket, maybe, are your oil and coolant mixed? Another likely possibility is that your turbo shaft seals are blown and the oil is leaking there, are you still on the stocker?
    #11
  12. absolute_DSM
    Jan 29, 2006
    1,552
    6
    Boise, Idaho
    This is going way overboard. Pull your oil pan. If you literally ran it out of all oil, you will know. Metal doesnt like to rub on metal without some type of lubricant.
    #12
  13. schoffs4
    May 5, 2006
    77
    When you pull your pan im shure you'll find spun rod bearings at least. By your noise description it will be cheaper to buy a used engine. When you drive with no oil pressure rod bearings are usually the first to go, from there the whole engine is filled with metal filings and metal chunks that destroy everything in its path including crank bearings cam caps all the way to your turbo. Sorry will not be a cheap fix. If you fix the engine or buy a new or used one make shure you flush the oil lines to turbo or you end up buying one seen it many times good luck.
    #13
  14. TSIfreek
    TSIfreek Proven Member
    DSM Profiles:
    Dec 14, 2003
    1,642
    13
    cary, Illinois
    Im sure the motor is garbage from head to crank.
    #14
  15. silver bullit
    silver bullit Proven Member
    DSM Profiles:
    Jan 27, 2006
    1,540
    6
    martinsburg, West_Virginia
    Driving with no oil=Your motor is toast, at the least it needs to be replaced very unlikely you motor can be rebuilt
    #15
  16. dsmulla
    dsmulla Proven Member
    DSM Profiles:
    Jun 27, 2007
    157
    Scarborough, Ontario_Canada
    Regardless if your rod bearings are toast, you have most likely scratched your crank. Sorry to break it to you man, but its time for a six-bolt swap!
    Regards
    Osman
    #16
  17. dSmgs-T
    dSmgs-T Proven Member
    DSM Profiles:
    Oct 26, 2007
    374
    harleysville, Pennsylvania
    first guess would be rod knock...:toobad:
    #17
  18. turboglenn
    turboglenn Proven Member
    Nov 5, 2007
    5,359
    74
    RIpley, West_Virginia
    You may, just maybe, in some sort f act of god get lucky. I did once when i was 16, the mini-van i was driving lost it's oil drain bolt and all it's oil.. It started knocking horribly (loud clacking..way more than ticking or ticking) and i stopped it there and walked home... Looked at it with a flashlight the next day and came back with an oil drain bolt and some oil and that same van lasted another 129k miles before we gave it to goodwill... you just may get lucky, it's worth buying a few quarts of oil and at least see if you can buy a few months of driving to work while you save for the new motor you're going to need anyway.. by lucky i DON'T mean your motor is fine. I mean you MIGHT be able to drive it for a few weeks to months as you save for a replacement engine. Do a 6 bolt swap if you can.. Best of luck
    #18
  19. blcknspo0ln
    blcknspo0ln DSM Wiseman
    DSM Profiles:
    Jul 31, 2003
    5,435
    75
    Central, New_Jersey
    Pull the oil pan and see for yourself. Having us all speculate isn't going to get your car running any faster. Do that and report back with what you see.
    #19
  20. absolute_DSM
    Jan 29, 2006
    1,552
    6
    Boise, Idaho
    Remember, this is a DSM. They can be reliable, but without oil.... yikes. :cool:
    #20
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
