Driving With Bad Knock Sensor?
Posted by xwade01, Apr 30, 2007
Please Support Kiggly Racing
  1. xwade01
    xwade01 Probationary Member
    8
    Joined Sep 13, 2006
    Waterloo, Iowa
    I drive a 90 Eclipse GST, and it throws a CEL code a right after a few minutes of driving. I had a buddy check the code and he says it was a code 31. From what I believe thats a bad knock sensor. I only boost to about 6-7psi in 1st gear, then 9-10 in 2-5 gears. It does have goo comming off the sensor so I'm pretty sure it's bad. Is driving with a dead bad knock sensor bad? And is it okay if it's not beat on or is it just a no-no??
    From what I searched I couldn't really find much detail on my question about driving. It also has many topics for the knock sensor. All the help will be greatly appreciated, thanks!!
    Log in/Register to remove ads
  2. dsmdizzle
    dsmdizzle Proven Member
    89
    Joined Jan 7, 2006
    Ogden, Utah
    First off, no it is not smart to drive without a knock sensor. But, you can. I went through the same deal just a week or 2 ago when I couldnt afford the sensor. When the cel pops on for the knock sensor it automatically tells the ecu that there is a problem so it tells it that there is knock. When sensor picks up knock it retards the timing, in turn making the car feel slow. All i did was take the sensor out of the block ground it out so it sends no signal. Then wrap the sensor with a thick rag and zip tie it so that it doesnt pick up road noise as knock. Now you are driving with no knock sensor. You can blow your car to bits so DO NOT HOT ROD IT.
    My DSM:
    Loading...
  3. 95blackGsTurbo
    95blackGsTurbo DSM Wiseman
    3,985
    72
    Joined Aug 10, 2003
    Cottage Grove, Minnesota
    You can do it but your car is going to have no power. Just get it replaced as soon as you can.
    My DSM:
    1991 Eagle Talon TSi (sold)
    Street Build
    14b   manual
    1998 Eagle Talon TSi (sold)
    Street Build
    T28   manual
    Loading...
  4. xwade01
    8
    Joined Sep 13, 2006
    Waterloo, Iowa
    I have means to replace the sensor ASAP, but i'm in the same boat as you; No funds, or no way to get the sensor brand new to completely fix the problem. A buddy of mine says his looks pretty new, and it works. So he's going to give me his knock sensor from his TSi and hopefully that'll solve the case. As for me driving it, i'm not hot rodding it at all. I usually just shift around 3-4k rpm's, and let boost get to about 5 and thats about it. I don't try to drive, but if I have to get somewhere thats only way.
  5. spyderturbo007
    spyderturbo007 DSM Wiseman
    2,312
    51
    Joined Dec 20, 2002
    New Cumberland, Pennsylvania
    Actually, driving the car with a knock sensor CEL, will dump the ECU into limp mode. Not a good idea.
    My DSM:
    1997
      manual
    Loading...
  6. xwade01
    8
    Joined Sep 13, 2006
    Waterloo, Iowa
    Well I read a few threads about how to take the knock sensor off. The outcome is I have to basically cut that 1 and 1/16 wrench in half to get to the knock sensor and properly take it off. Well is there any other way to remove it without cutting tools in half, maybe a different route or tool to get it off??
  7. freshlane
    freshlane Proven Member
    392
    Joined Sep 4, 2006
    Windy City, Illinois
    i had the problem a few weeks ago before I bought a new one. I drove it that way for about a week. MY motor is fine, BUT..... I tried my best to keep out of boost.
    My DSM:
    Loading...
  8. spyderturbo007
    2,312
    51
    Joined Dec 20, 2002
    I've never pulled a knock sensor off a 1g, so I can't help you there. But Craftsman wrenches are guaranteed for life, no matter what you do to them. ;)
    My DSM:
    1997
      manual
    Loading...
  9. xwade01
    8
    Joined Sep 13, 2006
    Waterloo, Iowa
    Well good news, I replaced the knock sensor and check engine light went off. It made a helluva difference, and it made it feel like a whole new car!! Boosting 10-12 psi through all gears now. All i'm waiting for now is the data logger.
  10. hansfase
    hansfase Probationary Member
    8
    Joined Apr 23, 2007
    muskegon, Michigan
    i am almost positive i have a burnt up knock sensor also, but it is not throwing me a check engine light... WTF, is that posible?
  11. Glliw
    Glliw Proven Member
    428
    Joined Dec 18, 2005
    Panama City Beach, Florida
    yes, mine is dead as well, about to order a new one,but it does not always throw a code if its just on its way out.
    My DSM:
    Loading...
  12. gc3nym06
    gc3nym06 Probationary Member
    3
    Joined Jul 12, 2007
    whitestone, New York
    can any one ### tell me where the hell my knock sensor is located ? 93 talon non turbo..:cry:
  13. Savage Talon
    Savage Talon Proven Member
    291
    Joined Oct 3, 2004
    North Bay, California
    You don't have one on a non-turbo.
    My DSM:
    1991 Eagle Talon TSi AWD
    11.561 @ 128.830 MPH
    Loading...
  14. Guzman08
    Guzman08 Proven Member
    801
    7
    Joined Jun 16, 2009
    Valley Wide, Texas
    What r the symptoms of a bad knock sensor
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
