Please Support ExtremePSI
Please Support STM Tuned
2G doubt with 4g64 ecu
talontsiawd08
163
Sep 20, 2012
Chihuahua, Central_America
Ok i have a problem, my friend has a spyder with 4g64 engine, he need other ecu, can anyone help me to know What is the correct ecu?????
It is the old ecu...
A friend from another state in my country selling this ecu ...
My question is ... Can I use this ecu?
Thanks
These numbers are small print
E2T68274
I have other question...
Can I use metal ecu from spyder 96 like this...
Thanks
I am pretty sure that for the ECU, the part numbers need to match exactly. My alldata says E2T68285 or E2T68284 for the 4g64 gs.
Also, this is not an Appearance/Interior/Exterior issue.
Is there any page where I can check which computers are compatible for 4G64
This one.
You could go to Ebay and do a search on "4g64 PCM" and see what you come up with. I don't know what you would get into though, if you plugged in an ECU from another 4g64 vehicle, or if it would start, or even fit into the harness.
OK well I hope you found the correct ECU. The old/original ECU in your first post is for a 96-98 2.4 Federal Spyder. The other "E2T68274" is for a 96-98 2.4 California Spyder . It may work but I think looks for other sensors.
