1Gina2G
- 810
- 2
- May 6, 2011
Beaufort,
South_Carolina
I'm currently trying to pull out the engine block with the transmission at the same time, so I know I have to drop the transfer case and both shafts in the tramsmission.
I took both wheels off, but both hub nuts on each side are WAY to tight it seems unreal. The cotter pins were removed. I thought the hub nuts may have been reverse threaded but I saw someone else ask about it on here and they are not.
I ended up unbolting everything else needed to take out both shafts from the transmission, and with the hub nuts still on the shafts I can only budge the passenger shaft mostly out the transmission but not all the way. I can't tell but it looks like there's less than an inch still in the transmission. I know I have to atleast get the drivers side hub nut off, so I was wondering if I did, would it be possible to get clearance to pull the passenger shaft out when the engine is getting lifted out ? Or do I really need to get both of these hub nuts out?
What gets me is that this car just got back from the shop from replacing both my front axles and brakes/brake rotors, so these hub nuts are brand new, you can see the shiny brass compared to everything being rusted before. It just seems to be way to tight like they over-torqued it at the shop with a huge breaker bar. Me my dad and a friend couldn't break it loose with are breaker bars and the air impact gun. Going to just keep soaking it in PB and hope it breaks loose, but I'd say the only thing i havent tried is torching it and that nut breaking tool someone posted on here, but i'm not sure if it's a good idea to try to break a brand new nut, probably alot harder than a rusty nut.
