DIY Supercharger 4G63...(warning lots of photos..)
Posted by JayRome, Nov 23, 2010
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support Strictly Import Motorsports
  1. JayRome
    JayRome Proven Member
    Dec 12, 2008
    133
    38
    Victoria, Australia
    a few people have requested pictures and or plans regarding my old Supercharger set up on my 4g.. (mods if this thread needs to be moved to correct section please do so..)
    this may clear some things up, i have lost alot of detailed photos due to a HD getting currpted but i can answer anyones question in regards to the set up...
    the supercharger used was an Eaton M45 from a Mercedes C200 Kompressor
    any questions just ask... i would suggest building everything on a spare engine, it makes things alot easier..
    warning: i wont be held responsible if you blow your s*#t up :p
    extractors/headers to cope with the boost: (i just recycled my old tri-y's and turned them tuned length)
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    manifold design:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    #1
    carmiencke likes this.
  2. JayRome
    Dec 12, 2008
    133
    38
    Victoria, Australia
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    (i wouldnt try and weld alloy with a mig, it sucks balls, but it works... kinda...)
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    (Using the stock aircon belt tensioner for the supercharger belt)
    [​IMG]
    #2
  3. rayrayx11
    rayrayx11 Proven Member
    DSM Profiles:
    Aug 8, 2008
    124
    riverside, Rhode_Island
    interesting... never seen it done like this.
    #3
  4. JayRome
    Dec 12, 2008
    133
    38
    Victoria, Australia
    #4
  5. AlphaVision
    AlphaVision Proven Member
    DSM Profiles:
    Jan 28, 2007
    259
    Sofia, Europe
    What's that charger?
    A friend of mine is doing something similar with an Eaton M62. Can you tell was it good? Pros and cons?
    Thanks!
    #5
  6. pj91gsx
    pj91gsx Freelancer
    DSM Profiles:
    Nov 25, 2007
    1,884
    7
    Stuart, Virginia
    where did you get the super charger from?
    #6
  7. JayRome
    Dec 12, 2008
    133
    38
    Victoria, Australia
    Pro would be no lag at all, matched with the right cams it feels and pulls like a bigger engine as well as having a wider power band.. also scaring the s*#t out of big block owners when they hear the whine under a mitsu bonnet...
    Con would be that sometimes Superchargers are more expensive then a turbo in regards to its parts and replacements, and tuning.. some tuners freak when they see a supercharged on a worked 4cyl....
    other wise same as turbo... but without the kick in the back of the head..
    LOL Ebay US.....
    #7
  8. AlphaVision
    DSM Profiles:
    Jan 28, 2007
    259
    Sofia, Europe
    Thanks for the info. I have more questions :)
    How about hp loss to spin the charger? What is the brand/model of the supercharger? What cams did you use? Any dyno numbers?
    #8
  9. JayRome
    Dec 12, 2008
    133
    38
    Victoria, Australia
    loose around 5-10%ish power to spin the charger (depending on the charger design wise, can be more or less), more torque, the instant boost makes up alot of the lost power.. add a sandwich plate cooler between the supercharger and the manifold and you can make alot more of that lost power back.....
    its in the first post... Eaton M45 from a Merc C200/180 Kompressor
    and no i didnt get enough time to dyno and tune properly before the supercharger died racing someone in the mountains..... (it was a 2nd hand unit couldnt expect much)
    #9
  10. AlphaVision
    DSM Profiles:
    Jan 28, 2007
    259
    Sofia, Europe
    All right. Thank you for the info. I appreciate it. One last thing. What boost and charger RPM@engine RPM was the charger running?
    #10
  11. JayRome
    Dec 12, 2008
    133
    38
    Victoria, Australia
    that i dont remember, the pully was 1/3rd smaller then the stock VR4 4G63 pully...
    from memory it was around 3psi ish from idle 1krpm and 8psi constant after 2.2krpm that...
    #11
  12. skatershawn
    skatershawn Proven Member
    DSM Profiles:
    Feb 27, 2009
    929
    10
    Austin, Texas
    plan on getting a new supercharger??
    What are you plans for it now?
    Keep us updated!
    #12
  13. JayRome
    Dec 12, 2008
    133
    38
    Victoria, Australia
    yes i have been looking for a replacement supercharger, but at the moment can not seem to find one...
    currently running an EVO8 turbo which replaces the supercharger, i do miss the S/C whine though, it did turn alot of heads...
    #13
  14. 9!'clipseDOHC
    9!'clipseDOHC Moderator
    DSM Profiles:
    Aug 24, 2003
    3,448
    153
    El Paso, Texas
    Very interesting! Good job on building it! That takes a lot of desire and ingenuity, especially since its so easy just to slap a turbo on.
    #14
  15. laser90
    laser90 Proven Member
    DSM Profiles:
    Sep 9, 2003
    197
    West Palm Beach, Florida
    I'm speechless...... This is a ####ing cool ass build! Props to you man.
    #15
  16. Imback
    Imback Proven Member
    DSM Profiles:
    Nov 8, 2006
    898
    15
    Elmont, New_York
    Very cool first time i've seen that. This should be moved to custom fabrication. How much power are you making at 8psi?
    #16
  17. JayRome
    Dec 12, 2008
    133
    38
    Victoria, Australia
    i'd say it was making an easy 150kw at the front wheels before the S/C died..
    when it did hit the dyno i got 57kw at 38% before my fuel system said no more (n/a ECU and injectors).... slapped on the VR4 ecu and injectors and she was back to more power but pinged slightly due to the maps being off....
    cheers for the comments guys....
    i would love more people to give the Supercharged way a go, they sound awesome and can still keep up with the turbos and you dont normally hear a supercharger whine on a ### car...
    #17
  18. coty
    coty Probationary Member
    Nov 15, 2010
    30
    lonaconing md, Maryland
    wow
    this is nuts
    #18
  19. SD99GST
    SD99GST Proven Member
    DSM Profiles:
    Sep 6, 2008
    203
    Oakland, California
    Would not believe it if I didn't see it. Insane build.
    #19
  20. spooln4fun
    spooln4fun Proven Member
    DSM Profiles:
    Jul 9, 2005
    440
    Belpre, Ohio
    It is a very interesting build and perhaps we(well 1g owners) could use the exhaust from a non turbo 4g that would eliminate the exhaust fab. As far as the intake that is another story.
    How was it getting the belt for the s/c as well as making those belt tensioner mounts?
    #20
  21. Zdrummer15
    Zdrummer15 Proven Member
    Aug 19, 2009
    700
    3
    York, Pennsylvania
    My thoughts exactly. I definitely won't be going this route, but it's still cool to see that someone gave it a try. A guy I lived with at college last year is doing a supercharger set-up on his Subaru 2.5RS though. I don't remember for sure, but that may even be the same supercharger he has. Either way it's a pretty cool build. If you ever swap back to a SC make a comparison to the turbo you're currently running. I'm sure a comparable turbo will put up much better numbers, but it would still be interesting to see the difference.
    #21
  22. BIRDCLAWTSi
    BIRDCLAWTSi Supporting Member
    DSM Profiles:
    Apr 13, 2009
    506
    3
    Danbury, Connecticut
    I was stoked when i saw your car in the widebody thread you posted, I never saw one in the u.s., Then i realized that you were in australia, Bummer.
    Either way, Cool car and props to you for thinking out of the DSM Box. It gave me a new approach to things. Much like Paul Volk (99Gstracer) did with his compound set up. I love seeing custom work. Later.
    -Dave
    #22
  23. me4g63t
    me4g63t Probationary Member
    DSM Profiles:
    Oct 2, 2010
    fresno, California
    This is one sick dsm bro.
    #23
  24. motozachl
    motozachl Proven Member
    DSM Profiles:
    Jul 15, 2008
    907
    15
    Cleveland, Ohio
    This is very interesting to say the least
    #24
  25. JayRome
    Dec 12, 2008
    133
    38
    Victoria, Australia
    yer some of the non turbo 4g64 stock manifold are already tri-y design so its easy if you know what your doing..
    as for the belt, its actually not hard, just used string to see how long it had to be, then went to my local parts shop and requested a belt this big with 4 ribs in it... you really have to play around with the pully's to get it exat but if your mechanicaly minded it should be easy....
    its a fun project if anyone attempts it..
    #25
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
