TurboConvert
- 41
- 0
- Feb 26, 2004
Richmond,
Virginia
I am in the process of upgrading this car and my next step is a reasonable FMIC (ebay), homemade 2.5" mandrel bent MIG welded IC pipes and an 40% alch /60% water injection setup to make way for high boost. I am following the DIY for this link:
http://members.cox.net/stevemonroe/AlcoholInjMod.html
I am having trouble deciding where to place the nozzle/s. I have seen installations just before the IC and ones in the UIC pipe. I have also seen installations with both. What is the point of spraying into the intercooler? wouldn't this just make the mix condense in the intercooler? Also, why a boost pressure activated switch in lieu of a UIC temp probe with a threshold temp to activate a relay to the pump? Also, what are the advantages of the Aquamist nozzles over the NOS nozzles?
Another problem is that I cannot find the Shurflo pump specified in the DIY. I can however choose between these two Shurflo pumps does anyone know which is the correct choice?
http://www.northerntool.com/webapp/...oductDisplay?storeId=6970&productId=527&R=527
http://www.northerntool.com/webapp/...uctDisplay?storeId=6970&productId=7273&R=7273
If there are any chemists out there, what is the bonding configuration for H2O and CH3CH2OH to the C8H18 + ~18% O2 ?? How do the extra Hydrogens help the burn rate? at this mix what would be the flash point temp?
Thanks in advance.
Also, if this is too much of a newbie question, please move to the appropriate forum, thanks.
I am relatively new to these forums since the demise of DSMTalk ;(
Thanks in advance.
