Dipstick melted....
Posted by rival, Dec 4, 2017
Please Support Miller Import Parts
  1. rival
    rival Proven Member
    123
    13
    Joined Dec 12, 2004
    aiken, South Carolina
    So not sure if this is the correct place to post this but haven't heard of anyone else having this problem.... I recently did a track day at Roebling road and the rubber or plastic piece on a 1g dipstick that seals to the dipstick tube disintegrated and fell down the tube into the oil pan... apparently the heat between the exhaust runners where the dipstick sits gets too hot. The manifold is ceramic coated. I am curious if anyone has had this happen or has any ideas of a solution... I was thinking about a billet handle if there is one... or a universal flexible dipstick to route it somewhere away from the exhaust... anyone have any ideas?
    Log in/Register to remove ads
    My DSM:
    1995 Eagle Talon TSi AWD
    Road Race Build
    GT30   manual
    Loading...
  2. Marchev
    Marchev Proven Member
    313
    44
    Joined Jan 31, 2009
    Niles, Illinois
    Throw a blanket on that manifold and you wont have that issue. I think its a better solution than rerouting the dipstick
    My DSM:
    Loading...
    Murdertalon and TSiAWD666 like this.
  3. tunedbysaturnsl
    tunedbysaturnsl Proven Member
    106
    24
    Joined Jan 27, 2010
    Newport News, Virginia
    My DSM:
    1997 Mitsubishi Eclipse GST
    212.4 whp   212.4 lb/ft
    Loading...
  4. rival
    rival Proven Member
    123
    13
    Joined Dec 12, 2004
    I had it heat wrapped before but wasn't happy with it.... got really flaky and if you brushed against it it would just flake off the manifold... and I was considering the billet handle from Frontline Fab but wasn't sure if the O-rings they use to seal would get too hot and fail as well...
    My DSM:
    Road Race Build
    GT30   manual
    Loading...
  5. 2gmitsueclipse
    2gmitsueclipse DSM Wiseman
    1,969
    562
    Joined Jul 13, 2005
    Auburn Hills, Michigan
    I would probably look at making a heat shield for the area if you are seeing temps that high. Not necessarily on the manifold, but protecting other components in the area. If it is getting that hot, any hoses, sensors, electrical wire/connectors are also at risk. If you have relocated such items, you could get creative for the dipstick. you could make a round tube that connects around the handle portion that extends an inch or two down. I should be a slightly larger diameter so that is is not directly touching the dipstick. You could then wrap that with gold reflecting tape. Using the F&F dipstick may transfer heat more so than what you already have.
    My DSM:
    1998 Mitsubishi Eclipse GSX
    Autocross Build
    T25   manual
    1999 Mitsubishi Eclipse GST
    Street Build
    16g   manual
    1990 Plymouth Laser RS Turbo
    Autocross Build
    14b   manual
    Loading...
    bling5tatus likes this.
  6. turbosax2
    turbosax2 Moderator
    3,312
    100
    Joined Nov 19, 2006
    Gibsonia, Pennsylvania
    A manifold blanket is the real answer to the problem, but I also got the FF handle for peace of mind after melting mine. In my experience, even good ceramic coating is inferior to a nice blanket.
    My DSM:
    1999 Mitsubishi Eclipse GSX
    13.543 @ 100.000 MPH
    Loading...
  7. chrysler kid
    chrysler kid Proven Member
    1,185
    256
    Joined Dec 20, 2002
    Mckinney, Texas
    Its specifically called "turbo manifold blanket" its not heat wrap at all. Its on eBay and runs about $80~120 or so.
    And yes I ran my car without the factory heat shield and if you pop the hood on a hot day after some boost you can feel the heat come at you right away
    Loading...
    Murdertalon likes this.
  8. 2gmitsueclipse
    1,969
    562
    Joined Jul 13, 2005
    This would work fine if the OP was running an OE/FP style manifold. From the OP's build, I noticed a tubular manifold with the dip stick between runners.
    My DSM:
    Autocross Build
    T25   manual
    Street Build
    16g   manual
    Autocross Build
    14b   manual
    Loading...
  9. gsxeclipse102
    gsxeclipse102 Proven Member
    518
    122
    Joined Mar 8, 2003
    carmel, New York
    Do what i did and bent the dipstick tube. Leave it bolted to the block and heat it up with a heat gun. Then bend it outwards towards your p/s pump. Once you warm the metal up it moves around pretty easily and doesnt kink( unless you try to go 90 degrees).
    My DSM:
    1991 Eagle Talon TSi AWD
    Street Build
    GT35   manual
    Loading...
    PlanZero likes this.
  10. chrysler kid
    1,185
    256
    Joined Dec 20, 2002
    Mckinney, Texas
    Ok ok, so he should put a factory exhaust manifold back on, and put the stock turbo back on, and then put the stock heat shields back on. :p
    Loading...
    wasabi37 likes this.
  11. Turbo2g
    Turbo2g Proven Member
    214
    35
    Joined Oct 13, 2017
    Fallbrook, California
    I say re-rout it. When you do modifications, you have to make stuff work. You are no longer able to run heat shields, so the dipstick can't handle it. Up to you if you want to shove a metal one in, or simply bend the tube. Iv'e found that most aftermarket sticks aren't accurate and I have the dremel a line on myself to match the factory stick. Thats my .02.
  12. 1990TSIAWDTALON
    1990TSIAWDTALON Moderator
    2,696
    776
    Joined Nov 14, 2013
    Independence, Kansas
    ^^^ THIS
    This is how I ran my dipstick. No way it would last in between glowing red runners. Yes it is highly modified, by hand, carefully taking the bend out of the tube with a tubing bender. I had to clear a WG also but it works fine in that position.
    My DSM:
    1992 Eagle Talon TSi AWD
    Street Build
    14b   automatic
    1990 Eagle Talon TSi AWD
    13.620 @ 108.460 MPH
    13.612 @ 107.760 MPH
    Loading...
  13. Bo0sTeD 4G63
    Bo0sTeD 4G63 Proven Member
    219
    15
    Joined Aug 31, 2008
    Miami, Florida
    I just wrapped my headers and it fixed my engine bay temps. The only thing I have heard is people cracking there manifolds because of wrapping the manifold.
    My DSM:
    1997 Mitsubishi Eclipse GSX
    Street Build
      automatic
    Loading...
  14. Murdertalon
    Murdertalon Proven Member
    194
    35
    Joined Jul 7, 2016
    East side, Washington
    You know a heat shield can be anything that deflects the heat. obviously its not going to be easy to make one for that jumble of exhaust but you could do it. I used a bread pan bent a bit to fit and secured in place with steel braided cable. Bread pan value village 7$, steel cable and crimp 7$ walmart, carabiner steel with screw style clasp home depot 4$.
    My DSM:
    Street Build
    15.9 @ MPH
    Loading...
  15. ChessmoDSM
    ChessmoDSM Proven Member
    80
    26
    Joined Apr 22, 2017
    Burlington, Vermont
    Have an engine pic of the setup?
  16. rival
    rival Proven Member
    123
    13
    Joined Dec 12, 2004
    this is currently the exhaust setup minus the heat wrap, it all flaked off so I had it ceramic coated.. I have been working on a heat shield for the sake of all the other components like power steering, alt. etc.. but as far as the dipstick problem, it started to get brittle with the heat even when I had the wrap on it because as you can see its in a terrible spot.. I may try 1990TSIAWDTALON's idea and bend the tube forward, but that may not be enough... keep in mind that on the road course I am in boost for good amounts of time for prolonged periods of time, so there is a lot of heat created. I haven't had any issues with engine temps or oil temps, just the dipstick...
    My DSM:
    Road Race Build
    GT30   manual
    Loading...
    1990TSIAWDTALON likes this.
  17. Murdertalon
    194
    35
    Joined Jul 7, 2016
    This is before my suspension upgrade and upper strut brace. Budget heat shield haha, really I was like spend money to replace the factory heat shield that wont work when I get a FP exhaust mani would be silly. The hood would burn my hand after some driving around without any heat shield, now its warm, but not even hot. Using a turbo blanket might be a decent idea if its of good design and wont trap moisture. That steel cable is taught! I mean I crimped it kinda short so I had to really pull it into place. With tin snips and a welder I would modify it to bolt into place, which I will likely do at some point.
    My DSM:
    Street Build
    15.9 @ MPH
    Loading...
  18. rival
    rival Proven Member
    123
    13
    Joined Dec 12, 2004
    gotcha, and I will prolly make something similar, but with my original issue, if I place a heat shield over the manifold, its just going to trap heat around where my dipstick currently is. (see pic above) so I need to either relocate it or modify it somehow so after the heat shield is on its not going to melt the plastic/rubber of the dipstick..
    My DSM:
    Road Race Build
    GT30   manual
    Loading...
  19. Murdertalon
    194
    35
    Joined Jul 7, 2016
    they make sleeves out of the Silver heat wrap, alternatively I have made covers for stuff out of the Silver / sticky backed heat shield wrap stuff.
    https://www.amazon.com/Thermo-Tec-13575-Adhesive-Backed-Barrier/dp/B00029KC2K
    it's good for about 2000f ambient, won't work direct contact but you might get away with it and a metal dipstick
    My DSM:
    Street Build
    15.9 @ MPH
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Best Used Tires Boostin Performance ECM Tuning ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrications OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports Tire Rack VR Speed Factory
