different t28 turbos?
Posted by ofgofg, Apr 29, 2012
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
  1. ofgofg
    ofgofg Proven Member
    Nov 6, 2011
    101
    kc, Kentucky
    Im looking to buy a t28 for my 95 tsi awd. Its a bit confusing. As far as I can tell, there is a 1200+ $$ fp big t28 and then there is a 900+$$ garrett t28 for dsm. Whats the difference? Does one make more power than the other? Does one spool quicker? Does one hold boost better? Also, is it a good idea to get a 17 psi actuator? I think the garrett has either 8 or 10 psi from stock. Car is going to be fairly mild. Not looking to break anything, so not tuning for max performance. Quick spool, and improvement over stock are the goals.
    #1
  2. Bud92gsx
    Bud92gsx Supporting Member
    DSM Profiles:
    Jan 16, 2008
    7,809
    21
    Your moms house, BC_Canada
    Most likely the garret is a bb gt28.The fp t28 is a journal bearing t28.The t28 is a direct bolt on for your car.
    Although.Unless you have deep pockets,my suggestion would be going with a 14b for a 1/4 of the price. Pm jusmx141 for a 14b.;)
    #2
  3. JusMX141
    JusMX141 Moderator
    DSM Profiles:
    4
    Dec 13, 2005
    12,536
    475
    Greensburg, Pennsylvania
    Wrong- both are journal bearing. The FP T28 has a stronger actuator and a different (better-flowing) turbine wheel...the compressors are the same.
    G-Pop Shop can convert a non-blown T25 to a Big T28 for around $700- that's the low end of the scale. Your other option is to buy a Small 16G which is a more common turbo with nearly the same potential and better reliability.
    #3
  4. Bud92gsx
    DSM Profiles:
    Jan 16, 2008
    7,809
    21
    What aboot the garrett gt28r.That's the one I was talking about.I was not aware there was a journal bearing garrett gt28.Let me check the garrett site.To make sure I didn't know about the journal bearing one.
    To my suprise, the garret site does not list a 28 journal bearing.
    #4
  5. JusMX141
    JusMX141 Moderator
    DSM Profiles:
    4
    Dec 13, 2005
    12,536
    475
    Part # 705329-0002
    #5
  6. Bud92gsx
    DSM Profiles:
    Jan 16, 2008
    7,809
    21
    I bet you knew that off the top of your head didn't you.ROFL
    Hold on this is a good one.Jusmx141's motto,Eat,Sleep,Turbo.
    Somebody Pchop that.
    #6
  7. Latch
    Latch Proven Member
    DSM Profiles:
    Feb 13, 2012
    37
    Quebec, QC_Canada
    I own a FP Big28 and i really like it. Spool fast and keep boost to high rpm.
    #7
  8. Pipnorcali
    Pipnorcali Proven Member
    DSM Profiles:
    Oct 29, 2011
    850
    54
    Grass valley, California
    If you got smog then a 16g doesn't fly , keep a eye out in the classifieds I just saw a used one pop up.
    #8
  9. eligst21
    eligst21 Proven Member
    DSM Profiles:
    Dec 13, 2010
    264
    Chico, California
    On smog, it depends on where you are at. I pass smog with my 16g, if they ask i claim its a first gen 14b and they dont say anything. But dont take my word on it. Could be different elsewhere.
    #9
  10. Latch
    Latch Proven Member
    DSM Profiles:
    Feb 13, 2012
    37
    Quebec, QC_Canada
    You need to do smog test every year ?
    We don't have that kind of test here :)
    #10
  11. 4g63tc
    4g63tc Proven Member
    DSM Profiles:
    Nov 20, 2002
    1,036
    6
    Palmcaster, California
    Pretty Much in SoCal if it fits under the heatsheild most smog techs have no idea what turbo it is. Smog Refs however....
    #11
  12. TSI_93
    TSI_93 Proven Member
    Apr 19, 2012
    229
    Huntsville, Alabama
    Put a heatshield on that bi*** and tell them it's oem and even has oem part numbers on it.
    #12
  13. ofgofg
    Nov 6, 2011
    101
    kc, Kentucky
    It looks like the ebay vendor obx has a 2g replacement turbo they are saying is t25 based. Has the correct intake elbow and such for a 2g stock intake system. Wondering if thats any good. So is it worth the extra 300+ dollars to get an FP big t28 versus a 900 dollar garrett t28?
    #13
  14. re-rx7
    re-rx7 Proven Member
    Jul 19, 2011
    316
    ardmore, Oklahoma
    I ahve the Garret T28. Perfect turbo. I love it especially if you never plan to make more than 300whp.
    #14
  15. JusMX141
    JusMX141 Moderator
    DSM Profiles:
    4
    Dec 13, 2005
    12,536
    475
  16. re-rx7
    Jul 19, 2011
    316
    ardmore, Oklahoma
    I got mine from BNR.
    #16
  17. jordan1g
    jordan1g Probationary Member
    DSM Profiles:
    Jan 10, 2011
    pace, Florida
    So glad we don't have Amy tests here in Florida we can basically get away with whatever set up we want here
    #17
  18. ofgofg
    Nov 6, 2011
    101
    kc, Kentucky
    Alright, so I guess its a moot point now. I scored that gt28 off ebay. So, for now Im going to run it at stock psi using stock boost solenoid. When I get the IC piping fixed, it will get a spearco big side mount, and an evo IX recirc valve. Perhaps later this summer I will rewire the fuel pump, and get dsm link.
    #18
  19. Latch
    Latch Proven Member
    DSM Profiles:
    Feb 13, 2012
    37
    Quebec, QC_Canada
    I actually run my FP T28 at 18 psi with stock fuel pump, stock 450cc injectors, PR FMIC and 1G Bov, the injduty is + or - 98% on WOT on ecmlink V3 and my wb at 10.2:1. So i figure you can raise to boost to 15 psi safely with your ic piping fixed.
    I will swap my stock fuel pump this week end for a 255lph and my stock injectors for new fic 650cc.
    #19
  20. ofgofg
    Nov 6, 2011
    101
    kc, Kentucky
    Alright, so I got the ebay gt28 for 600 bucks. As in the ad it came with no factory packaging. So, how can I tell its the real deal? Any markings or characteristics i should look for? It sais garrett Japan. Is that right? I thought they were made down under?
    Looks like probably not a GT28,, but an older T28. Its got a white painted strip on both wheels,
    A/R .48 M24
    WXLH
    .49
    N5S
    85PH1
    TR0759
    LG 0107J
    705329-2
    Waste gate actuator sais:
    PF
    CO
    430819-283
    53395 06038
    #20
  21. JusMX141
    JusMX141 Moderator
    DSM Profiles:
    4
    Dec 13, 2005
    12,536
    475
    Post pics of the wheels. :thumb:
    Although if the number in the listing is what's found on the tag of the center housing, I'm confident you got the real deal.
    #21
  22. ofgofg
    Nov 6, 2011
    101
    kc, Kentucky
    Pictures of turbine wheels.
    #22
  23. Latch
    Latch Proven Member
    DSM Profiles:
    Feb 13, 2012
    37
    Quebec, QC_Canada
    Does it have the adjustable actuator ?
    #23
  24. JusMX141
    JusMX141 Moderator
    DSM Profiles:
    4
    Dec 13, 2005
    12,536
    475
    Definitely a T28, even has the higher-flowing 9-blade turbine. You got a steal.
    #24
  25. ofgofg
    Nov 6, 2011
    101
    kc, Kentucky
    AWSOME! The stock number is 705329-2. no zeros in front of the 2. Unfortunately it was packed in the raw, no plastic bag to seal out crud,, so in the pics you can see little particals of what seems to be foam or plastic. Going to take it to work today and blow it out real well using compressed air,, then see about cycling some oil through it.
    No adjustable actuator, but I may want to replace the actuator with higher psi,, or adjustable?
    #25
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
