evileclipse98
- 36
- 0
- Jul 14, 2009
Lake Village,
Arkansas
Besides the engine and tranny, what are the differences in the chassis of a rs/gs and a gst/gsx? I mean primarily the engine bay. Thanks.
Note: This feature currently requires accessing the site using the built-in Safari browser.
Eh, maybe, don't know. I know the engine/tranny is opposite but what else? Engine cradles, mounts, cables, wiring, instrument cluster. Also, is insurance much higher on a gst/gsx than a rs/gs? Let me know.
insurance should be the same. they count the Eclipse as a sports car. if you buy a Tsi it is cheaper cause its in a different insurance bracket (or whatever the damn insurance term for it is). and if you get a Laser RS insurance is even cheaper. they look at the car more than the engine. eclipses are higher risk, according to how they calculate that stuff....basically more of them on the road than the Talon or Laser so they have more accidents. higher risk due to higher collision, thefts and such than the other cars. funny how its the same car but insurance is cheaper for he less common ones
I saw your thread about buying a junk 2g and hating on the 4g63 and crankwalk. (I was just giving cliff notes to that thread and not trying to start a pointless internet fight). Putting a 420A into a GSX would cost a lot more than building a 6-bolt and putting that in. If you're worried about crankwalking a 7-bolt first look at your power goals for the car and see what clutch would be needed to put that power to the wheels. If you need a clutch to hold 350+whp, build a 6-bolt and be done with it. It wouldn't be much more than building up the 7-bolt. But putting a 420A or EVO 8 engine into an AWD car that has the mounts for the engine and trans in the opposite locations would cost big bucks in fabrication.
Non turbo RS/GS has better compression then a non turbo GST/GSX. So I would go with the RS/GS stock for stock.
No such thing as a non turbo GST or GSX. The GST is FWD turbo and the GSX is all wheel drive turbo. A RS or GS might have 130hp (can't remember exactly) and a GST or GSX will have 195hp. The 4g63 is meant to be a turbo engine where as the 420A is not. The 4g63 has a much better aftermarket scene. Build a 6 bolt, swap it in, enjoy all wheel drive traction for the 1/4 mile. Dun. Unless you're one of those guys that thinks going from a 55mph roll is a "race". Then I'd sell the GSX and get a GST. Either way, don't get a GS or RS to build up. Not a lot of options for aftermarket performance.
There are plenty of 6 bolt swap threads. Research and research some more. Swap in the 6 bolt to the GSX and be done with it. If you plan to use it for mainly the drag strip I'd even leave it auto.
Um yes there is. One that doesn't have a turbo installed in it, and don't say it can't be because I've seen it done. Where you been at bro? Also RS/GS has 140hp stock.
Judging by your post, I wonder if you've even owned a 420a...
Well yeah, if you take the turbo off of a turbo engine that has lower compression (because it was built for turbo charging) chances are it'll have less hp than a higher compression engine. Bro. 130hp, 140hp... I said I couldn't remember exactly but I was close. To clarify, all GST's and GSX's came from the factory turbo charged with 195hp. Can a 4g63T engine be made N/A, yes. Why someone would want to take the turbo off is their business. Bro.
And no, I never have owned a 420A. I like to make a lot of horsepower easily so I didn't waste my time and went straight to the 4g63T. But, I do think a 420A build is impressive because it's not something done very often.
OK. I see where this is going and I'm not going to get drawn into some pointless internet brawl.
To the original poster. The important things to look at are... What is your budget? What are your hp goals? What do you want to use the car for? If the car is in good condition, and you have 1500-2000 to throw at it, I say do a 6 bolt swap with forged internals. I'm kind of in the same boat as you. I just bought a high mileage 99 GSX that runs great right now... But I plan to build a 6 bolt short block in the near future just in case the 7 bolt goes bad. But, think about the 3 question I asked above. That'll help detemine the best route to go.
