Differences between a TD05-20g & a TD06-20g?
Posted by 1661, Jan 10, 2005
Please Support Feal Suspension
  1. 1661
    1661 Proven Member
    11
    Joined Jan 10, 2005
    Singapore, Asia
    Hi,
    What is the max HP output of a TD05-20G & a TD06-20G?
    Can anybody advise the spooling characteristics?
    Thanks!!!
    Log in/Register to remove ads
  2. DSMnewbi
    DSMnewbi Banned Member
    101
    Joined Jan 8, 2005
    Cocoanut Grove, Illinois
    I have a td05h/20g and spool up feels as good as a big16g and much more power.
  3. 1661
    1661 Proven Member
    11
    Joined Jan 10, 2005
    Singapore, Asia
    Thanks for the post..but can you let me know how much power can this td05-20g churn out?
    Do you happen to know the max efficient boost it can handle?
  4. BluemeanieTSi
    BluemeanieTSi Proven Member
    339
    Joined Nov 17, 2002
    Freeport, Pennsylvania
    i've seen like 100 less hp between the 2 under normal circumstances
    My DSM:
    1995 Eagle Talon TSi AWD
    11.600 @ 136.000 MPH
    Loading...
  5. 1661
    1661 Proven Member
    11
    Joined Jan 10, 2005
    Singapore, Asia
    Can i say the TD05-20G can whip out 400hp with supporting mods & a TD06-20G can churn out 500HP max?
  6. BluemeanieTSi
    339
    Joined Nov 17, 2002
    close to what ive been told
    My DSM:
    Loading...
  7. 1661
    1661 Proven Member
    11
    Joined Jan 10, 2005
    Singapore, Asia
    so ideally it will be better to get a TD06-20G & can still retain close to stock spool up...maybe 300 to 500rpm later perhaps...
  8. BluemeanieTSi
    339
    Joined Nov 17, 2002
    for the money i would just go with the td06-20g because of the price differece isn't much
    My DSM:
    Loading...
  9. markgholland
    markgholland Proven Member
    309
    Joined Jun 7, 2003
    Williston, Vermont
  10. 1661
    1661 Proven Member
    11
    Joined Jan 10, 2005
    Singapore, Asia
    what can i do with my exisiting ti-turbo with 10.5T hotside from a Evolution MR?
    maybe i should just sell it off & get a TD06-20G..
  11. DSMnewbi
    101
    Joined Jan 8, 2005
    This is for Buschur Racing's 20g off their website..
    This specially modified TD05/6 Hybrid 20G is the quickest spooling 500+ HP turbo we have ever run. It has run 10.70's at 130+mph and made 450hp to the wheels with our proven combinations... all without the aid of nitrous! This was the turbo we used to run the first-ever 10sec blast in an AWD DSM! Tym Switzer - 10.98@124.79 1991 Eagle Talon - Full weight, full interior, full exhaust, etc.
  12. cfisher
    cfisher Proven Member
    368
    4
    Joined Dec 21, 2002
    olathe, Kansas
    TDO6 will hit full boost around 4K.
  13. 1661
    1661 Proven Member
    11
    Joined Jan 10, 2005
    Singapore, Asia
    full boost at at 4k rpm!
    tats pretty impressive imho...
    at wat max boost can tis td06-20g holds before boost creep?
  14. cfisher
    368
    4
    Joined Dec 21, 2002
    olathe, Kansas
    I went with a Tial 38mm External Wastegate so boost creep is really not an issue for me. Not sure if you go internal. Matters about your exhaust flow, ect..
  15. DSMnewbi
    101
    Joined Jan 8, 2005
    If you buy it with an internal gate you HAVE to get AT LEAST a 34mm flapper, no question. The stock WG just won't be able to hold it back.
  16. 1661
    1661 Proven Member
    11
    Joined Jan 10, 2005
    Singapore, Asia
    any cons if i re-divert my waste-gate gas into the exhaust?
  17. 1661
    1661 Proven Member
    11
    Joined Jan 10, 2005
    Singapore, Asia
    Thanks dude for the info....i will take note of this.... :)
  18. Turbo442
    Turbo442 Proven Member
    52
    Joined Oct 21, 2004
    Portland, Oregon
  19. Tort9320g
    Tort9320g Proven Member
    64
    Joined Jun 22, 2004
    West Lawn, Pennsylvania
    Well, according to dsmtimes.org I've got the fastest currently running 20g car and I'm using the TD05H turbine wheel. I highly doubt I'd pick up 100hp by going to the 06 or even 06H!
  20. BluemeanieTSi
    339
    Joined Nov 17, 2002
    i thought it was a given that how turbos are rated and how they work in the real world were 2 different things? guess i should have explained that better:
    that's what the rating difference is not real world applications ;)
    My DSM:
    Loading...
  21. 1661
    1661 Proven Member
    11
    Joined Jan 10, 2005
    Singapore, Asia
    The timeslip is impressive for your FP20g-05H!
    Currently wat is your dyno figures? Max torque at which rpm before it tapers off, likewise with the HP..Mind sharing?
  22. Tort9320g
    64
    Joined Jun 22, 2004
    Couldn't tell ya since I've never had it dynoed. This was on a 7 bolt, internally gated, 264/272s, street FMIC, 550s, 2900# race weight. Just got done installing a water/air IC and 780s, will be hitting the dyno to get it tuned before I run again, I'll be sure to post the info.
  23. 1661
    1661 Proven Member
    11
    Joined Jan 10, 2005
    Singapore, Asia
    will be anticipating your dyno results...
    thanks dude...
  24. Batty200
    Batty200 Proven Member
    127
    Joined Feb 17, 2003
    lancaster, Pennsylvania
    I beleive that HP difference is if you have a 20G stuffed into a TDO5 compressor cover. A TDO5 turbine and a TDO6 compressor is what Buschur ran and also what Hahn sells. Hahn uses a 10cm turbine much like the EvoVIII 16G and it is a much better turbine than a 7cm for a 20G compressor.
    Later
    Loading...
  25. NJdsmguru
    NJdsmguru Proven Member
    148
    Joined Oct 5, 2003
    lindenwold, New Jersey
    in december ran 11.5 @119 on my td06 20g...6 bolt,ross 9.0:1 pistons,eagle rods,web cams 546/547,sprearco fmic,ported head,650's,2g maf,act 2600,hks 40mm external,afc,weight interior basically gutted
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
