Difference between Turbo 4g63 and Non-Turbo 4G63 blocks???
Posted by Birdoprey, Jul 7, 2005
Please Support JNZ Tuning
  1. Birdoprey
    Birdoprey Proven Member
    69
    Joined Jun 17, 2005
    Snyder, Texas
    Is there any differences 4g63 blocks with Turbo's or Non-Turbo's?
    Log in/Register to remove ads
  2. fn8uup
    fn8uup Proven Member
    43
    Joined Jul 2, 2005
    huntington, West Virginia
    i think its just the pistons and injectors and computer besides the actual turbo related parts
    ive only been here a week or so so dont hold me too it their may be more
  3. tsiAWD91x
    tsiAWD91x Proven Member
    149
    Joined Jun 30, 2005
    Philadelphia, Pennsylvania
    N/T block has no oil squirters and turbo block is taped for em
    My DSM:
    Loading...
  4. EclipseSH21
    EclipseSH21 Proven Member
    150
    4
    Joined Aug 17, 2004
    East Lyme, Connecticut
    Check out the N/T forum, there is more information on this topic there. Also, try a search, this topic has been discussed before, and I know there are many differences, just I can't remember them off the top of my head.
  5. ChicksDigBoost
    ChicksDigBoost Proven Member
    309
    12
    Joined Nov 14, 2004
    St. Charles, Illinois
    Yes use the search, also the NT block does not have knock sensor it does have a hole for one so one can be installed.
  6. Birdoprey
    69
    Joined Jun 17, 2005
    Snyder, Texas
    I did search. Guess i did'nt word it correctly. I either find waaaay unrelated stuff or get too specific and don't get anything.
    I did find that the N/T blocks did'nt have the oil squirters. Did'nt find out about the lack of knock sensor.
    I'm looking to buy an already prepped block and found several N/T blocks. Was'nt sure if i could swap the different componants from my Turbo block or if there were other differences.
    Thanks for the help!
  7. timloomis
    timloomis Proven Member
    778
    13
    Joined Jan 28, 2003
    duncan falls, Ohio
    just the oil squirters are different.it has a hole for the knock sensor,just a different location.
    My DSM:
    1992 Eagle Talon TSi
    14.796 @ 93.970 MPH
    Loading...
  8. IHeartTurbo
    IHeartTurbo Proven Member
    1,351
    15
    Joined Aug 15, 2003
    Weld, Maine
  9. mavisky
    mavisky DSM Wiseman
    4,031
    20
    Joined Sep 13, 2002
    Atlanta, Georgia
    Don't forget some of the other stuff is different as well.
    nt 4g63
    no locating pin on crankshaft
    Pistons are different design
    Motor mount arms (front and rear attached to block) are different
    water pump pipe doesn't have outlet for oil-water cooler
    lower thermostat housing doesn't have the fitting for the oil-water cooler
    no lines for the oil water cooler
    head plugged where oil feed comes from
    no drain hole on oil pan
    different tb
    different cams
    intake manifold lacking one vacuum source on the manifold
    Alot of this stuff is easily replaced, but it depends.
    Of course the stuff mentioned above about the oil squirters not being there and the hole being there for the knock sensor are true.
  10. Birdoprey
    69
    Joined Jun 17, 2005
    Snyder, Texas
    Will i need to tap the hole for the knock sensor or is it already tapped? I assume it would be ok to use in a different location?
    Also, on the oil squirters, can i just swap the over or will i have to drill and tap some holes???
    Thanks again for the reply!
  11. 92awddsm
    92awddsm DSM Wiseman
    3,934
    79
    Joined Jan 17, 2004
    Chesterfield, Virginia
    Are you just getting a bare block or a short block? Seems like everyone is giving you info about a short block.
    As a bare block, no oil squirters or even holes for them. You would have to have the mounting locations machined, drilled, and tapped for them. Im not going to say you do or dont need them because there is too much contraversy on that subject and it will turn into more of an opinion war than anything. Do a search on oil squirters and you will see what Im talking about.
    As for the knock sensor, the hole should already be tapped. No real need to be concerned about it. I have heard of a few that werent tapped but I have yet to see one.
    My DSM:
    1992 Eagle Talon TSi AWD
    12.320 @ 115.440 MPH
    Loading...
  12. Birdoprey
    69
    Joined Jun 17, 2005
    Snyder, Texas
    Yeah, i'm talking about just the bare block. I pulled my motor(turbo) and it may be just about as cheap as well as much less down time picking up an already machined and prepped block. I would use my crank and all accessories and put in new eagle rods and weisco or JE pistons.
  13. 92awddsm
    3,934
    79
    Joined Jan 17, 2004
    Im sure someone will disagree with me but if you are going with a foged piston, I wouldnt worry about the oil squirters. Like I said, search it and you will see all the other threads obout them.
    My DSM:
    Loading...
  14. Birdoprey
    69
    Joined Jun 17, 2005
    Snyder, Texas
    Yeah, i did the search. I'm gonna run forged internals. Not worried about the squirters...
    Thanks for the search tip!
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
