Inkdlyfe
- 438
- 7
- Feb 23, 2016
Summer feild,
Florida
So in addition to my previous post about driving the car with no fic connected right now, i got everything together and what not idles good high bu steady, it idles at 2k rpms which i assume is normal due to having a turbo on it, the car does have stock injectors and stock ecu thats about all thats stock on the car, but any ways i went to move it around the drive way and it moved in reverse perfectly fine no problems at all but then went to move forward ya not happening its like the fuel just cuts off but if you press the clutch quick it will shoot back to idle and roll a little forward with the quick momentum u gave it before it stalls, when both front tires are off the ground i was able to keep the tires moving and make it thru each gear no problem didn't die then so its only when under load it wants to die, what could this be ? do i need to use a missing link till i get my fic back or what ? i am getting my 880cc injectors tested tomorrow so ill more then likely have those on the car too
car is 420A NOT 4G63
