12hayden12
- 0
- Jan 10, 2013
Medicine Hat,
AB_Canada
hey hopefully I can explain my situation in a way that makes sense because I need help! when I start my car and keep holding the clutch pedal down the starter motor keeps rotating, even though I let go of the key and let it rest in the ON position. when I release the clutch the starter motor is deactivated. any time I push the clutch pedal down while the car is running, the starter motor will once again engage and start making a painful grinding noise. I know it is not a problem with the clutch because I tried putting it into gear and it worked perfectly.
it is as if the key is being held in the START position when it actually isn't. I would appreciate if you guys could help me out thanks!
title correction. compressing* clutch activates...
