Degreeing in a cam without adjustable gears?
Posted by forcefed86, Jan 5, 2010
Newbie Forum - Beginner DSM modification questions and discussions. Common, repetitive, and general discussions will get dumped here from other tech forums. Unless you're a Probationary member you shouldn't post threads here.
Please Support Miller Import Parts
  1. forcefed86
    forcefed86 Proven Member
    May 23, 2006
    1,003
    8
    wichita, Kansas
    Just wondering if anyone uses the offset bushings like below to degree in cams? Extremely standard practice in small block v8's.
    Just looking strictly at the cost POV. I'd like to retard my exhaust cam a few degrees but have a hard time dishing out the 300 dollars for a set of adjustable cam gears.
    Amazon.com: Competition Cams 4760 Cam Degree Bushing: Automotive[​IMG]
    #1
  2. 95blackGsTurbo
    95blackGsTurbo DSM Wiseman
    DSM Profiles:
    Aug 10, 2003
    3,983
    71
    Cottage Grove, Minnesota
    #2
  3. forcefed86
    May 23, 2006
    1,003
    8
    wichita, Kansas
    Thanks, I'm aware of that method. But to say one method is "right" while all others are wrong is a pretty broad statement.
    You can degree in the cam just the same with bushings. I've done it many many times, but not on a DSM product.
    Looking more closely at the OEM cams this won't work, so never mind.
    #3
  4. snowborder714
    snowborder714 Moderator
    DSM Profiles:
    Oct 15, 2006
    11,885
    169
    Downingtown, Pennsylvania
    I'm not sure how this would work since the cams and cam gears have a locating pin.
    #4
  5. IgotBoost91
    IgotBoost91 Proven Member
    Jan 4, 2010
    131
    Benwood, West_Virginia
    couldnt you just move the exhaust cam gear one way a couple teeth?
    #5
  6. 95blackGsTurbo
    DSM Profiles:
    Aug 10, 2003
    3,983
    71
    It is kind of like cam degreeing a V8. They have dowels as well, you have to drill out the hole on the gear itself so it can move on the car and install bushings like the one pictures but smaller. I have not seen these yet for DSM's. Like having an eccentric on the cam like we have in our rear suspension.
    ** If you move the gear a tooth it can cause valve to piston contact. These are interference motors. **
    #6
  7. snowborder714
    DSM Profiles:
    Oct 15, 2006
    11,885
    169
    I'm not familiar with V8's, but that's interesting.
    #7
  8. 95blackGsTurbo
    DSM Profiles:
    Aug 10, 2003
    3,983
    71
    Basically you are making the hole bigger that goes over the dowel so the gear can move with the cam remaining stationary.
    #8
  9. tkelly27
    tkelly27 Proven Member
    Mar 11, 2007
    1,568
    19
    Gresham, Oregon
    Then the offsets push the camshaft forward or backward.
    The only real problem I could see is that there are adjustable cam gears for less than $200 that don't require the removal of the cam gear to adjust the phasing. If nobody makes those, then they'll have to be custom done and by the time you're done machining the stock cam gear and getting those made, you may as well have adjustable ones that are easier to work with.
    #9
  10. 95blackGsTurbo
    DSM Profiles:
    Aug 10, 2003
    3,983
    71
    The bushing doesn't go on the cam it goes over the dowel. The gear is still centered on the cam with the bolt.
    #10
  11. JusMX141
    JusMX141 Moderator
    DSM Profiles:
    4
    Dec 13, 2005
    12,541
    475
    Greensburg, Pennsylvania
    You just have to be looking for deals, and be ready to buy when they become available.
    I picked up the Hayame adjustable gears that are going on my AWD from a closeout deal on eBay. They were $85 shipped, brand new-in-box. They're a *10* on the bling chart, and they're a hell of a lot easier than fumbling around small degree bushings.
    #11
  12. forcefed86
    May 23, 2006
    1,003
    8
    wichita, Kansas
    Yea your all right, it would probably be cheaper in the long run to just run the adjustable gears. Just an idea!
    A "couple teeth" would be a massive change. I'm running the BC stage II cam (272). So they are pretty horrible to start with. Usually requiring around a 5* adjustment. U may get by with 1 tooth, but you'd have to be really careful.
    Anyone know how many degrees of offset 1 tooth equals?
    #12
  13. luvmygst
    luvmygst Proven Member
    DSM Profiles:
    Oct 17, 2005
    781
    13
    radford, Virginia
    I think that the cam gears have 48 teeth so one tooth would be 7.5 deg. Dont quote me on the number of teeth. Just take 360 and divide by the number of teeth and that will give you the answer.
    #13
  14. JusMX141
    JusMX141 Moderator
    DSM Profiles:
    4
    Dec 13, 2005
    12,541
    475
    Fixed.
    #14
  15. 99gst_racer
    99gst_racer Moderator
    DSM Profiles:
    Apr 5, 2003
    8,934
    406
    Coloma, Michigan
    It's a neat idea but not worth the headache with what adjustable gears cost. I picked mine up for $150 out the door.
    360 / # of teeth on the gear
    #15
  16. 95blackGsTurbo
    DSM Profiles:
    Aug 10, 2003
    3,983
    71
    Coming from the man who decided to do a compound turbo setup as opposed to just a big single. This should be a cakewalk LOL.
    #16
  17. 99gst_racer
    DSM Profiles:
    Apr 5, 2003
    8,934
    406
    Coloma, Michigan
    ROFL But if I could have bought the compound turbo set-up for $400, I would have done just that. ;)
    #17
  18. LiquidX
    LiquidX DSM Wiseman
    DSM Profiles:
    Sep 19, 2008
    6,594
    91
    Anywhere, Pennsylvania
    So when you degree a cam you are still infact rotating the cam to make it exatcly at TDC with the timing marks on everything else. I'm assuming it would only really be a partial tooth adjustment which is why you can't just rotate the cam a tooth on it's own. Am I correct on this statement?
    #18
  19. Force Fed 4g63
    Force Fed 4g63 Proven Member
    Feb 27, 2009
    105
    Charleston, South_Carolina
    I had my FP2's degreed on the stock cam gears, it doesn't take very long either. I was really glad I did too because they were a decent bit out of time and I noticed the difference big time. There's a guy in Florida who is currently making kits for people to do it themselves. He's very active on another DSM forum I'm on but I don't believe he's on here. If anyone wants some more info they can pm me.
    #19
  20. 99gst_racer
    DSM Profiles:
    Apr 5, 2003
    8,934
    406
    Coloma, Michigan
    Correct. Degreeing a camshaft is rotating the cam ever so slightly without moving the cam gear or any other part of the rotating assembly. It's usually a partial tooth adjustment (typically 1-5 degrees which is less than 1 tooth).
    I'd like to know how you degreed your cams with stock gears.
    #20
  21. JAXWHITE1G
    JAXWHITE1G Proven Member
    Dec 16, 2009
    62
    4
    Jacksonville, Florida
    The guy in Florida would be me. I have built a system to degree OEM cam gears using eccentric bushings. I can adjust the cams in the vehicle 1G and 2G without removing the timing belt. With this system there is no chance of the bolts working loose and the gear slipping time and the eccentrics can be changed quite quickly. Here are some photos.
    The basic tools.
    [​IMG]
    A machined guide.
    [​IMG]
    Slide the gear out and install shim to hold it.
    [​IMG]
    Lock the gear and remove the alignment pin.
    [​IMG]
    Drill the pin hole to fit the bushing.
    [​IMG]
    Remove shim and push the gear back on cam.
    [​IMG]
    Install bushing.
    [​IMG]
    Install bolt.
    [​IMG]
    I can get 9 deg adjustment each way at 1 deg intervals.
    [​IMG]
    [​IMG]
    I have done 5 cars now and plan on doing many more. I have machined 150 bushings and updated my tooling from the above. I don't have any updated photos.
    When I get enough posts I'll show off my TMIC in my 1G.
    Mike
    #21
    99gst_racer and snowborder714 like this.
  22. Force Fed 4g63
    Feb 27, 2009
    105
    Speak of the devil Mike! I'm glad you showed up because you can explain it waaaay better than me LOL. Mike very generously degreed my cams for me, and I know for a fact I got the power I did in part because the cams were degreed! Thanks again Mike!
    #22
  23. ruben2566
    ruben2566 Probationary Member
    Feb 2, 2007
    11
    Orlando, Florida
    Nice work. Cam gear manufacturers are going to hate you, (Chinese).
    #23
  24. 99gst_racer
    DSM Profiles:
    Apr 5, 2003
    8,934
    406
    Coloma, Michigan
    Yes, nice work. I guess we now know it's possible to properly do this.
    I can honestly say that I would never do it due to the affordability of aftermarket adjustable gears, but props for figuring it out and getting it done. :thumb:
    #24
  25. snowborder714
    DSM Profiles:
    Oct 15, 2006
    11,885
    169
    Very neat Mike! If you plan on making the kit to sell to members here, you should look into a Supporting Freelancer account ;)
    #25
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
