eclipse012
- 183
- 10
- Apr 17, 2008
canada,
AB_Canada
So I have been battling this water temp situation on and off for this whole season and part of last. I spent a ton of time opening up the front of my cars air flow as well as boxing in the fmic to the radiator with adding a bit of ducting. I just read in a thread a couple weeks ago that while logging with evoscan, I should be logging the coolant scaled value and not just the regular coolant temp? The scaled is what the ecu see's? So if this is true then my temps are fine and i'm in the ball park being in the 200-205 degree region give or take a few. So I might have done all this extra work for nothing.
Now the only issue I have is that I am still unsure to why the Defi water temp gauge I installed is still reading at 220+ or more at times while evoscans scaled temp says it around the 205 to 210 ish. I installed the sensor to the defi water temp gauge into the water neck of the thermostat housing. Anyone know why i get different readings between the two? I assume the defi gauge is true and the ecu converts it to which ever else and maybe in the process it alters the temp a bit? Is there a way to get the defi racer gauge to read the same? Or do i just have deal with knowing there is a 15+- degree difference on the gauge reading at all times?
