2G Dash light replacement
rambow70
96
Feb 26, 2012
Fishers, Indiana
So I've read how and what bulb to get but where do I buy it? What is bulb #74?
From spyderdrifter "There's 2 screws that hold the gauge bezel on. 4 screws holding the gauge cluster in. After that, just pull the cluster out and you can access the bulbs. If you're replacing them with LEDs, the bulb size is #74"
So using his info I should get this bulb, anyone know how many? Too cold to pull the cluster twice haha
https://www.superbrightleds.com/mor...led-bulb-high-power-instrument-panel-led/709/
Just want to make sure these are a drop in replacement. Thanks for the probably obvious.
Thanks! Would anyone know how many you would need? The ones on my speedometer and rpm cluster are going bad. I am not worried about the other bulbs.
Ordered 7 74-xHP, a post said 74-xHP3 but they were not listed that way on the part picker. Hopefully those are correct.
