Custom Valve Cover
Posted by JAXWHITE1G, Jan 27, 2010
Custom Fabrication - TIG/MIG welding, jig-building, metal working, fiberglass, carbon fiber, and other custom fabrication projects.
Please Support Extreme Turbo Systems
  1. JAXWHITE1G
    JAXWHITE1G Proven Member
    Dec 16, 2009
    62
    4
    Jacksonville, Florida
    I had been looking fora JDM Mitsubishi valve cover for a long time but wasn't ready to part with the cash that everyone was asking.
    I decided to make an original. Starting with a Hyundai cover I shaved the lower letters to half there height. I then shaved the rings around the spark plug holes to allow hood clearance for my ACCEL coils. Then I sculpted the MITSUBISHI lettering and Diamond Star from aluminum stock. I then aligned the letters and soldered them to the cover. Then a 3 color powder coat.
    [​IMG]
    [​IMG]
    Unfortunately this is the third white cover I have tried and heat seems to yellow them. I tried high temp clear paint and two different types of powder coating and they all have turned yellow after time and the white contrasts greatly with the coils. I believe I will strip it and go gloss black this time.
    [​IMG]
    Mike
    P.S. I plan on Ceramic coating my heet shield soon.
    #1
  2. romeen
    romeen DSM Wiseman
    Jul 12, 2006
    2,434
    29
    Vancouver, Washington
    You really did the Diamond Star symbol and "MITSUBISHI" yourself?! That must have taken some patience. Very impressive work.:thumb:
    What did you use to sculpt the letters?
    You definitely have a very unique looking engine bay. Can't say I've ever seen a TMIC on a DSM.
    Strong work.:)
    #2
  3. LiquidX
    LiquidX DSM Wiseman
    DSM Profiles:
    Sep 19, 2008
    6,594
    91
    Anywhere, Pennsylvania
    Looks pretty good I must say. Why go through all that work though? What are your intake temps with having the TMIC opposed to a SMIC or FMIC? IF they are turning yellow and you are just using a high temp clear, that may be your problel. Use the high temp colors and clear as well. Do you notice the powder coat cracking or staying sticky?
    @Romeen
    The Mitsubishi RVR actually utilizes a TMIC setup with their 4g. I got a full "JDM" long block minus the transmission and it came with the TMIC setup.
    #3
  4. 907gs-t
    907gs-t Proven Member
    DSM Profiles:
    Feb 3, 2009
    741
    5
    Juneau, Alaska
    That looks good indeed.
    #4
  5. Fabian
    Fabian Proven Member
    DSM Profiles:
    3
    Sep 5, 2008
    293
    Elizabethtown, Pennsylvania
    wow, SICK lookin valve cover. I've already read your multiple threads on dsmtalk about your top mount intercooler. You do awesome work!
    #5
  6. motozachl
    motozachl Proven Member
    DSM Profiles:
    Jul 15, 2008
    907
    15
    Cleveland, Ohio
    Oh wow that looks sweet :thumb: If you want to sell one of those slightly discolored ones pm me ;)
    edit: maybe not
    [​IMG]
    #6
  7. willydsm
    willydsm Proven Member
    DSM Profiles:
    Apr 1, 2006
    122
    3
    Toledo, Ohio
    Any pics of the car with the hood down and the tmic? I would like to see what it looks like with that.:hellyeah:
    #7
  8. 99gst_racer
    99gst_racer Moderator
    DSM Profiles:
    Apr 5, 2003
    8,934
    406
    Coloma, Michigan
    Very impressive work, Mike.
    You have much more patience than I do. :)
    #8
  9. 1990clipse
    1990clipse Proven Member
    Feb 4, 2008
    114
    Waco, Texas
    Not to sound like a broken record, but that is sick! I love the TMIC too. I think i speak for everyone here when i say that we need more pics of your car!
    #9
  10. 99gst_racer
    DSM Profiles:
    Apr 5, 2003
    8,934
    406
    Coloma, Michigan
    [​IMG]
    [​IMG]
    #10
  11. NeMiZiS
    NeMiZiS Supporting Member
    DSM Profiles:
    Jul 25, 2007
    1,339
    12
    Anchorage, Alaska
    The lettering looks really good!
    #11
  12. LiquidX
    LiquidX DSM Wiseman
    DSM Profiles:
    Sep 19, 2008
    6,594
    91
    As neat as it looks, the TMIC isn't very efficent at cooling. Heat rises folks so after sitting at a light, the intake temps are rising from the engine heat leaving through the TMIC. Clean none-the-less but good for performance.
    You had a white VC in one of the later pics, did that one turn yellow as well? I still think it's the brand of powder coat you are using. It is high temp powder and you are baking it properly after you spray right?
    #12
  13. EagleTSIawd
    EagleTSIawd Proven Member
    DSM Profiles:
    Mar 17, 2005
    329
    5
    Stayton, Oregon
    Subis have them from factory, I'd say it works just about the same as the stock sidemount. When parked you don't need cooler air so it won't matter if it gets a hot. I'm sure once rolling the air will cool It off rather quickly.
    I think if you painted the valve cover black and the lettering white, it would work out better.
    #13
  14. LiquidX
    LiquidX DSM Wiseman
    DSM Profiles:
    Sep 19, 2008
    6,594
    91
    Scoobies have a TMIC because that's the only place they can fit one in their tight engine bay. I agree though as you don't need it to be cool while sitting, however, it'll take longer to cool off the IC after the heatsoaking from idleing. I know it works, but just how efficently it works is the main question at hand.
    #14
  15. shredwin
    shredwin Proven Member
    DSM Profiles:
    Jul 6, 2008
    510
    Tampa, Florida
    She is so clean... nice job:thumb:
    #15
  16. AndrewD5418
    AndrewD5418 Supporting Member
    Feb 16, 2006
    1,153
    11
    West Bend, Wisconsin
    I suggest you read into how he has the TMIC setup.
    #16
  17. Natedsmeclipse
    Natedsmeclipse Proven Member
    DSM Profiles:
    Dec 4, 2007
    140
    Colton, New_York
    no that is a JDM valve cover they cost a lot and are hard to find i bought one once and have only seen them a few times on ebay. :hellyeah:
    #17
  18. LiquidX
    LiquidX DSM Wiseman
    DSM Profiles:
    Sep 19, 2008
    6,594
    91
    I'd like to know honestly, but I don't know where I would find that information. I was just stating the information I know about TMICs. I know if you have a pull fan on the bottom, that will help out as well. If you can get me a link to his IC idea I would appreciate it :thumb:
    #18
  19. Killa_dsm
    Killa_dsm Proven Member
    DSM Profiles:
    Aug 31, 2004
    1,094
    18
    Bay Area, California
    Very nice valve cover. Maybe you can make some custom ones and sell them for a profit?
    #19
  20. 97gst_spyder
    97gst_spyder Proven Member
    Sep 1, 2008
    1,967
    13
    Lakeland, Florida
    He has a fan attached to the bottom of his ic, so at stops/etc air is always moving. Also, you can tell that its a Hyundai lettering on the bottom that he ground down to make it look like a Mitsu one, and added the Diamond Star and Mitsubishi....
    #20
  21. 99gst214
    99gst214 Proven Member
    Apr 24, 2009
    213
    Champaign, Illinois
    Wow man very nice valve cover. I just finished shaving mine and that took me like 3hrs to do. I thought i was patient, but no where close to your level. Love the attention to detail. Awsome!!!
    #21
  22. jjrock5
    jjrock5 Proven Member
    Mar 19, 2006
    1,319
    8
    Around, Connecticut
    Sweet VC. :)
    #22
  23. Boosted98gsx
    Boosted98gsx Proven Member
    DSM Profiles:
    Oct 31, 2002
    2,071
    17
    Houston, Texas
    Really interested to see flow numbers (or IAT differences at speed) of air through that TMIC setup at 40+ mph where the airflow over the hood causes a "bubble". Just want to see some comparative cooling numbers of it vs a FMIC, and why you went that route.
    #23
  24. willydsm
    DSM Profiles:
    Apr 1, 2006
    122
    3
    Toledo, Ohio
    Where did you get the hood scoop? or did you make it? IDK if I want the tmic but i deffinitly want the hood scoop. I cant help myselfWTF I just love hood scoops, I am gona stick with a fmic but I could make an air intake with that, if you don't mind?
    #24
  25. romeen
    romeen DSM Wiseman
    Jul 12, 2006
    2,434
    29
    Yeah, but the RVR is not a DSM.;) Nonetheless, I didn't know that the RVR (or any Mitsubishi) used a TMIC. That's interesting to know.:thumb::) It looks like there would be a lot less IC plumbing with a top mount(?)
    I know, that's what I currently have on my imported 6 bolt motor.;):)
    #25
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
