davetheman81
- 163
- 0
- Jun 16, 2010
randolph,
Massachusetts
so it started out as a "jdm" or gvr4 valve cover, i liked it because it said mitsubishi. I installed with out any welding a -8 an fitting on the side for a catch can system, and a -6 an fitting were the factory pcv valve was, for a new pcv "-6 an line with check valve" system. here are the steps start to finish
grabbed a can of tal-strip from advanced and striped the red paint that was on it, then hit all the letters with 320,600,800,1000,2000 then polish
next and i wish i had more pictures, i went and got a -8an to 1/4 npt fitting and -6an to 1/8 npt fitting and drilled and tapped the vc for them, threaded them in with locktite, and then added some jb weld for strenght and that welded on look, then tape off everything
high heat primer
paint black and then tape off middle section
now paint green, then clear coat, remove all tape and add female fittings!
touch up spot that tape lifted
high heat primer
