Compound turbo dyno results
Posted by 99gst_racer, Aug 27, 2010
Please Support Strictly Performance Motorsports
  1. 99gst_racer
    99gst_racer Moderator
    8,963
    554
    Joined Apr 5, 2003
    Coloma, Michigan
    I had some fun on the dyno yesterday. It was a 2WD Dynojet, so I dropped the t-case and driveshaft and hit the road. The very first pull blew the tires clean off on the rollers before we even hit 6K rpms. Love that torque! We eventually had to turn the tire pressures down to 20 psi and use some sort of spray on aerosol traction promoter to get traction. Immediately, the clutch began to slip in the 5000-6700 RPM range and slowly catching back up. I'm pushing this ACT 2600 well beyond what it's rated for and I'm surprised it's done as well as it has thus far. But, it's time for a twin disk. The blank areas on the dynograph are where the rollers weren't accurately reading due to the clutch. And when it caught, it still wasn't catching 100%.
    Despite the slipping clutch, I was still able to squeeze out 609 WHP and 541 ft/lbs torque. This was at 47 PSI! But, the final pull also answered my question of whether or not the head was warped from overheating at the shootout. The head gasket popped somewhere between cylinders 2 and 3 and was pissing a stream of coolant out the back of the block. So, I'll have the head resurfaced this time around and should be all set. And I'll have to get a better clutch before I can see true and complete curves and peaks.
    This power curve is gnarly! This is exactly why it's an absolute blast to drive around on the street.
    We did some math and we feel it would have peaked in the 680-700 WHP range had the clutch held. And we would have started the pulls at a much lower RPM, but that was putting the clutch in an even tighter headlock.
    Datalog attached.
    Log in/Register to remove ads
    My DSM:
    Loading...
  2. BLINKY619
    BLINKY619 Proven Member
    1,028
    4
    Joined Feb 26, 2010
    SAN DIEGO, California
    47 psi is quite high... i know ill never reach that.. overall great numbers
    My DSM:
    Loading...
  3. Dsmj89
    Dsmj89 Proven Member
    2,150
    10
    Joined Nov 11, 2008
    Miami, Florida
    Damn nice power curve !
  4. noV8undrDIShood
    noV8undrDIShood Proven Member
    163
    Joined Jan 6, 2010
    Lewistown, Pennsylvania
    nice number paul.. seen the beast at the shoot out and was in absolute ahh..
    very nice setup man!!
    Loading...
  5. JusMX141
    JusMX141 Moderator
    12,604
    582
    Joined Dec 13, 2005
    Greensburg, Pennsylvania
    Quite impressive, Paul. Awesome to know one of my rebuilt 16G's is literally holding more boost and generating more airflow than any 16G on the planet. Between your car and Dave's HX40 setup, my turbos are setting all kinds of records this year!
    I still think Christi sabotaged your car so I wouldn't get a ride in it at the Shootout. :hmm:
    It would be interesting to see how running on an AWD dyno would've effected the power output with all four wheels turning....being FWD-only obviously helps with drivetrain loss, but your slipping clutch, melting the tires on the dyno, and the fact that you had to drop to 20psi all result in lower numbers too! :ohdamn:
    ...and of all places to get your car dynoed- Paul's High Performance? LOL Should've been a sign from the start.
    Loading...
  6. keilum
    keilum Proven Member
    35
    Joined Jun 19, 2008
    northport, Alabama
    Nice man love the setup !
    Loading...
  7. ninjai_ruken
    ninjai_ruken Proven Member
    489
    10
    Joined Feb 1, 2004
    Indianapolis, Indiana
    Having been here since around 04 watching everything you have done and continue to do is like watching a child grow into an adult! haha :hellyeah: Awesome numbers man! I love the set up and will continue to follow the build.
    My DSM:
    1990 Plymouth Laser RS Turbo
    390 whp   360 lb/ft
    Loading...
  8. VTEC_THIS
    VTEC_THIS Freelancer
    775
    18
    Joined Jul 20, 2006
    Tampa, Florida
    Wow!
    My DSM:
    Loading...
  9. GRAVEDIGGER
    GRAVEDIGGER Proven Member
    2,683
    89
    Joined Nov 26, 2007
    Uniontown, Ohio
    Nice results Paul. It will be interesting to see what it does with a twin disk in there.:hmm: Did you ever figure out why you lost coolant at the shootout? I thought I read somewhere that you thought someone may have messed with the radiator cap.:mad: I hope that's not true though.:pray: Thanks for keeping us posted and it looks like the compound setup is working it's magic as expected.:D
    My DSM:
    1991 Eagle Talon TSi AWD
    12.149 @ 115.940 MPH
    Loading...
  10. viperlp01
    viperlp01 Proven Member
    2,147
    64
    Joined Oct 9, 2006
    Kalamazoo, Michigan
    HAHA Paul looks sick man. So your telling me we need to get an AWD dyno at the shop ehh...
    My DSM:
    1997 Eagle Talon TSi AWD
    9.737 @ 140.310 MPH
    Loading...
  11. 99gst_racer
    8,963
    554
    Joined Apr 5, 2003
    Coloma, Michigan
  12. gofer
    gofer Moderator
    5,330
    670
    Joined Feb 18, 2006
    South Gilbert, Arizona
    Looks good Paul, I've been waiting for the dyno results for awhile from this setup but what about the video? LOL
    *EDIT* I'm glad you posted the video while I was asking for it, must have read my mind. Do you think its capable of 700 awhp?
    :dsm:
    My DSM:
    1997 Mitsubishi Eclipse GST
    Street Build
    11.634 @ 126.050 MPH
    Loading...
  13. snowborder714
    snowborder714 Moderator
    11,905
    193
    Joined Oct 15, 2006
    Mechanicsburg, Pennsylvania
    That's awesome Paul! I can't wait to take a look at the log.
    Damn do I want a ride in that :thumb:
    My DSM:
    1995 Mitsubishi Eclipse GST
    12.529 @ 110.820 MPH
    Loading...
  14. ninjai_ruken
    489
    10
    Joined Feb 1, 2004
    That things sound like a freaking beast man :hellyeah: I think my 97 Comp Trans Am ran into my garage and is hiding:cool: after I played that video!
    My DSM:
    390 whp   360 lb/ft
    Loading...
  15. 99gst_racer
    8,963
    554
    Joined Apr 5, 2003
    Coloma, Michigan
    Thanks for the kind words everyone!
    Hells yeah. :hellyeah:
    I'll definitely give you a ride in it at the SO next year. Better the car be 100% for a true experience anyway. :) What did Christi think of it?
    What's the parasitic loss difference between FWD and AWD? I always used 3% (15% for FWD and 18% for AWD), but was never sure how accurate that was.
    Right? I wish that was my shop. There's more toys and tools there than I'd know what to do with. LOL
    My DSM:
    Loading...
  16. JusMX141
    JusMX141 Moderator
    12,604
    582
    Joined Dec 13, 2005
    Can't wait, man. I think we should see it on the dyno at Buschurs as well to see just how your street car stacks up against some of the race-only machines!
    She had the female equivalent of a giant erection the entire time and has had nothing but good things to say ever since. Such a crazy issue with the coolant loss- I hope if someone was actually tooling with your rad cap that they have read your posts and realize the damage they did.
    I'm not actually sure what the difference is; it just seems to me that the t-case, driveshaft, rear diff, both rear axles, and the tires trying to spin the rear drums too would amount to more than 3%. I'm sure someone out there has calculated it.
    I've even heard that running with slicks on the dyno can have a drastic change in power output simply because of the low pressure and sidewall flex; when you figure how easily your street tires turned at standard pressure versus the 20psi needed to get the car to hook up I'm sure you lost some HP numbers there as well....but dyno conditions are rarely ever perfect for anyone, you know?
    Loading...
  17. 99gst_racer
    8,963
    554
    Joined Apr 5, 2003
    Coloma, Michigan
    I'm almost positive it was a defective radiator cap. It spins itself loose while driving. And I was really slow at catching my temp gauge rising. I honestly don't think anyone messed with it.
    You do that, and I'd be there playing on it like every weekend. :D
    You and Eric should make a point to come to the SO next year.
    PS - I didn't have much time at all to play with the tune due to swapping out the head gasket the day before yesterday. So, it's far from perfect, but definitely improved from what it was this past spring.
    ROFL It did sound amazing at 8500 RPMs inside that metal building. I wish the camera would have captured it the way I was hearing it. ;)
    Most definitely. I just wish I had the clutch to prove it. ;)
    My DSM:
    Loading...
  18. snowborder714
    11,905
    193
    Joined Oct 15, 2006
    Believe me, I want to go to the SO next year. Craig was bugging us about that a week ago. I told him Eric doesn't like driving his car more than 137 miles per year ROFL
    It's on my calendar - just need to convince Eric to give up some time and money to go.
    I'll play with the tune and see what there is to be changed and let you know.
    My DSM:
    Loading...
  19. Artago
    Artago Supporting Member
    1,772
    14
    Joined Nov 30, 2006
    North Vancouver, BC, Canada
    Sick numbers Paul. Good job buddy. :hellyeah::thumb:
    My DSM:
    1995 Eagle Talon TSi AWD
    Street Build
    50trim   manual
    Loading...
  20. JusMX141
    JusMX141 Moderator
    12,604
    582
    Joined Dec 13, 2005
    What the hell's your excuse? Craig drove something like 16 hours straight each way...hell even Lofty drove his DSM of questionable reliability 8 hours each way to attend! You can't let Lofty have one up on you like that!
    Loading...
  21. black_gst
    black_gst Freelancer
    1,618
    22
    Joined Jun 16, 2008
    IE, California
    those sound like fightin words to me LOL
    My DSM:
    1996 Eagle Talon TSi
    13.687 @ 103.210 MPH
    Loading...
  22. snowborder714
    11,905
    193
    Joined Oct 15, 2006
    2 years ago my brother's car was down and he said he was only going to the SO if he drove his car. This year I had come back from vacation in Europe that weekend. Next year I'll be there :thumb:
    My DSM:
    Loading...
  23. JusMX141
    JusMX141 Moderator
    12,604
    582
    Joined Dec 13, 2005
    Under normal circumstances I'd say that a European vacation is completely fun and worthwhile....but there's one weekend a year that a vacation in Europe or anywhere else in the world doesn't have sh** on Norwalk, Ohio. LOL
    You're a Moderator- your attendance is mandatory. :thumb:
    Loading...
  24. snowborder714
    11,905
    193
    Joined Oct 15, 2006
    The dates for the vacation weren't up to me. My aunt is only able to take certain days off because of being a principal.
    I've got to go next year. There's so many people I want to meet in person. That means I have A LOT of work to do on the car in the next year.
    My DSM:
    Loading...
  25. snowborder714
    11,905
    193
    Joined Oct 15, 2006
    FYI Paul, the attachment isn't working for me. Can you send me it in an e-mail please?
    My DSM:
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
