Comment my 16g porting to cure creep
DSM4LIFE-AWD
322
10
Aug 6, 2009
Trois-Rivieres, QC_Canada
Hey guys, I wanted to show you what I've done today. I hope it's gonna fix the 32PSI @ 5500RPM @ 46.2lbs/min I was seeing with my 16g evo3 knock off.
i went bigger on the flapper with mine, but it looks pretty good.
maybe clean it up with a sanding flapper, or not
edit: the o2 housing i would see if i can get that piece of pipe ground down more. might not be a huge issue but i see some buildup happening over time.
I gave a shot in the wastegate hole with a flapwheel and gain some more after taking the pics LOL ;)
Yeah that part of piping in the o2 is a real pita, don't really want to make the piping thinner ... It was worse before I start but still. I'll give it a little shot tomorow before installing.
Well sanding it would be a really good idea if I can control boost ...
Thanks :D
