Colorado springs
Posted by monster4g63tawd, Dec 28, 2010
Denver Area DSM Forum - Denver, Fort Collins, Colorado Springs, and surrounding front range area.
Please Support Boostin Performance
  1. monster4g63tawd
    monster4g63tawd Proven Member
    DSM Profiles:
    Aug 1, 2010
    136
    Fruita, Colorado
    just wondering if there is anyone that knows if they have any meets here in the springs. i just moved back here to the springs and my dsm is down for the time beeing but id like to go and meet some ppl at some meets around here or something, just gettin old not doin sh**.
    #1
  2. spyderdrifter
    spyderdrifter Supporting Member
    Classifieds Rating:
    100%
    DSM Profiles:
    6
    Jul 11, 2009
    2,744
    140
    Colorado Springs, Colorado
    I feel your pain. I know some meets go on up by Briargate mall once in a while, but I've been out of the scene since my last DSM was taken from me and now can't get my current one to run, so I'm not sure when meets go on and such.
    :hmm:
    #2
  3. monster4g63tawd
    DSM Profiles:
    Aug 1, 2010
    136
    Fruita, Colorado
    whats up with your dsm? im in the middle of a swap on mine so it will be out for a while kuz i just lost my job but id like to meet some ppl before i finish my swap
    #3
  4. spyderdrifter
    Classifieds Rating:
    100%
    DSM Profiles:
    6
    Jul 11, 2009
    2,744
    140
    What swap are you doing to yours? The tard I bought mine from (or even the owner prior to him) did a 6-bolt swap and I wasn't told about it when I bought it. So it wouldn't start under it's own power unless it was a push start. So I ended up fixing that problem and got to drive it for a whole 88.2 miles and then started having power issues. So I replaced a few more things and then it wouldn't start again. Then I found out it was a 6-bolt engine with a hacked '90 CAS and mutilated wire harness. Then I replaced the harness and got a new CAS and redid wiring for it and still nothing. So now I got it up on craig's list so if it sells, great, I'll buy one that runs, or if it doesn't sell, I'm still always trying to get it running. Gotta love DSMs, wouldn't be a DSM if it were easy to work on.
    I've been trying to meet more DSM people too, none of my tuner friends have respect for DSMs. Don't even know others who have them.
    #4
  5. monster4g63tawd
    DSM Profiles:
    Aug 1, 2010
    136
    Fruita, Colorado
    im in the middle of the 6bolt swap but i might just throw new bearings in it and cruize it till it lockes up again, i just want to drive it again. i think i was the one that sold you your harness actuailly.
    #5
  6. ESleazy
    ESleazy Proven Member
    Dec 2, 2010
    30
    Colorado Spring, Colorado
    Once I throw my starter in I will be good to go
    #6
  7. monster4g63tawd
    DSM Profiles:
    Aug 1, 2010
    136
    Fruita, Colorado
    i just did a starter on my car it was a bi*** but i did it from the top. i didnt think it would be possible but with monkey arms it is.
    #7
  8. spyderdrifter
    Classifieds Rating:
    100%
    DSM Profiles:
    6
    Jul 11, 2009
    2,744
    140
    Sweet, red s10 right? I want to drive mine and pisses me off every time I see one on the road knowing I can't drive mine.
    Just did a compression test on my car and it's severely low so this weekend I'm checking my piston rings and valves. Finally feel like I know the problem.
    :cool::hellyeah:
    #8
  9. monster4g63tawd
    DSM Profiles:
    Aug 1, 2010
    136
    Fruita, Colorado
    yeah is that the pickup version of the cyclone? sweet man if you need any help let me know man im alwayse down to help out
    #9
  10. spyderdrifter
    Classifieds Rating:
    100%
    DSM Profiles:
    6
    Jul 11, 2009
    2,744
    140
    Awesome. I might actually be pulling the engine and tranx out this weekend if my seal test shows the my piston rings are bad. If so, I'm gonna start preping for a stroker kit and block boring. Help is more than welcomed. (And yeah that was the truck). The harness went in pretty quick too btw. Definately a much cleaner look than the original.
    #10
  11. ESleazy
    Dec 2, 2010
    30
    monster..
    Did you have to remove the piping that goes into the throttle body to get at it?
    #11
  12. monster4g63tawd
    DSM Profiles:
    Aug 1, 2010
    136
    Fruita, Colorado
    most of whats going to be in your way is your wiring harness. i just dissconnected everything that was holding it there and moved it to the side then you do have to get the bottom bolt from the bottom side. you can pull the starter through the top though and drop the new one through the top. the only reason i did it this way is because i didnt want to take the exhaust off. i had to have a friend of mine hold the socket on the bottom bolt from the top while wrenching on it from underneath.
    and yes i do believe i had the piping off
    #12
  13. ESleazy
    Dec 2, 2010
    30
    Monster I sent you a PM... don't know if it went through though... hit me up when you get a chance.
    #13
  14. monster4g63tawd
    DSM Profiles:
    Aug 1, 2010
    136
    Fruita, Colorado
    i hope to have my car together sometime so i can meet some ppl and set up a cruise and grill maybe up pikes peak i havnt got to check out pikes peak yet but it seems like it would be fun to drive
    #14
  15. ESleazy
    Dec 2, 2010
    30
    Pikes Peak is tight.... I think it costs like $10 a person to get up there... and after like 3/4 the way its gravel
    #15
  16. monster4g63tawd
    DSM Profiles:
    Aug 1, 2010
    136
    Fruita, Colorado
    sweet. i love dirt roads, sucks for the paint but its fun as hell. i have alot of work to do on my car though and i lost my job before i could finish my build so i gotta find me a job. i still need to get machine work done on my new block and head then buy gaskets and bearings and my motor is done then still gotta get dsmlink but thats mainly it
    thats good to hear that it worked out for you atleast someone got some use out of it. if you need some help just let me know. you should still have my number if not just pm me when you figure out what your gonna be doing
    #16
  17. Project2G
    Project2G Proven Member
    Classifieds Rating:
    96.6%
    DSM Profiles:
    Aug 11, 2003
    958
    13
    Littleton, Colorado
    There is a meet every Saturday night at Shell Gas Station off Academy and I25. Also there is a meet every sunday night up here in Denver off I25 and Colorado at the 24hr starbucks. Some people come from the springs every sunday to go to this one because it's a decent turn out and a cruise after. Niether meets are strictly DSM only.
    #17
  18. ESleazy
    Dec 2, 2010
    30
    Nice I might hit that up this week or next.. what time do they usually head up there at?
    Project - nice setup.. did you do the battery relocation yourself?
    #18
  19. Project2G
    Classifieds Rating:
    96.6%
    DSM Profiles:
    Aug 11, 2003
    958
    13
    Littleton, Colorado
    I'm not sure what time people go to the meet in the springs off academy because I haven't been in awhile but I used to go at 10pm and stay until like 1am. The Denver meet is usually 9pm-12am-ish depending on when everyone leaves to go cruise then they usually go back to that spot.
    They battery relocation I did back in 2007 how ever im looking to pick up a new battery box since hey won't let me run this plastic one at Bandimere.
    #19
  20. ESleazy
    Dec 2, 2010
    30
    I've been looking to do a relocation. Would you be interested in doing the install? Would definetly compensate.
    #20
  21. monster4g63tawd
    DSM Profiles:
    Aug 1, 2010
    136
    Fruita, Colorado
    ill definately have 2 check it out. good thing its not strictly dsm as i will be in my friends subie regaurdless itd be cool to meet some people out here
    #21
  22. my1997gsx
    my1997gsx Proven Member
    DSM Profiles:
    Dec 21, 2007
    111
    A-Town, Colorado
    The meets are fun and have good turn outs as long as its not freezing balls out and the roads are not full of dirt from snow I went last winter all the time but have not made it out this winter at all. My brother has though and he said it was a good turn out.
    #22
  23. justinj07
    justinj07 Probationary Member
    Classifieds Rating:
    100%
    Dec 16, 2009
    21
    Davenport, Iowa
    I'll be moving out that way for a job somewhere around August, I'll have to hit ya'll up and see what kind of scene you're running :thumb:
    #23
  24. monster4g63tawd
    DSM Profiles:
    Aug 1, 2010
    136
    Fruita, Colorado
    hell ya man. im still working on getting my car running but im just waiting on my taxes to get the machine work done
    #24
  25. 98baileygsx
    98baileygsx Probationary Member
    Classifieds Rating:
    100%
    DSM Profiles:
    Mar 31, 2008
    3
    Pueblo, Colorado
    I know people think there is nothing in Pueblo,( which there mostly right) but if theres a meet up in the springs I'll go up there and another 2gb too thats worth checking out as soon as we finish up the wiring and the tune for it very soon :hellyeah:!
    #25
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
