Please Support RTM Racing
Please Support STM Tuned
2G Coil replacement
Spideydsm99
240
40
May 30, 2017
Cherryville, North_Carolina
Okay so I can’t find a single coil for a 2g 4g64 specifically. Here is the coil that’s on the car now.
Now I found that a coil from a 97-04 Montero has the exactly same looking coil.
So my question is will it work? I think it will because it looks exactly the same the plug is the same etc. but I wanted others opinion. Thanks!
Try an online mitsu parts store and compare the number. If you use the mitsu software asa you could just lookup the number directly and even better find out what models share what parts
I had CAPS open so here's what I could find:
1998-2004 Montaro Sport XLS with a 3.5L uses
MD314583 COIL,IGNITION ALL 02 1998.06.01..2004.07.03
MD349207 TRANSISTOR,IGNITION POWER ALL 01 1998.06.01..2004.07.03
2g Eclipse Spider with 2.4L uses:
MD336385 COIL,IGNITION ALL 01 1995.10.01..1999.06.03
MD326836 TRANSISTOR,IGNITION POWER ALL 01 1995.10.01..1999.06.03
Source: http://mitsubishi-motors.kiev.ua/1/
