Please Support ExtremePSI
Cockpit pics
Ohhchhittt
115
Oct 20, 2014
Naples, Florida
i have seen some posts on the cockpit but all the pics are either gone or links don't work. I would like to start a new thread for you to post pics of your cockpit.
I am also looking for ideas for mine. Like I want to remove the airbags and maybe do something nice in the passenger side airbag cubby. So post away
Don't have one of the whole dash, but the PO on mine painted everything purple and green carbon fiber (love the purple, hate the green). I just put a new cluster cover on and I'm working on changing the LEDs in the panel
Someone on eBay sells a carbon fiber tub to go in place of the passenger airbag.
What app is that running on your phone @TSiAWD666?
I use a RaceCapture Pro Mk2 from Autosport Labs for much of my data logging. I run their RaceCapture app on the phone connected to the datalogger via Bluetooth which gives me access to all the data as well as lap timing features. It is on the lap time display there which I use when racing. The app also live streams the data over the phone's cell connection to the Race Capture website for live and archival analysis.
Current ride. I've since added an ortiz dual vent pod with with aem digital oil temp and eventually I'm thinking maybe the spot for a moroso cut off switch in the other gauge location as the pod is pretty beefy
new car is a lot more, uh, quiet. I like it. I need to find myself a nice wheel. I was thinking of getting a good condition 1st gen talon wheel. Or an evo wheel. Anything else I like the look of is cheaply made, or way to expensive. Or from another OEM, and I am not sure how I would go about making it work if it would work at all.
Mine is relatively simple as well. Besides new carpet and headliner, I had the seats reupholstered and added gauges under the radio and homelink right by the shifter.
Working on a new gauge cluster though...
Digital odometer is not finished yet. It's run via an arduino. Need to finish up the programming and test it. Basically it just counts the vss signal pulses and turns it into mileage. I am not a programmer at all so it's been quite the learning curve. Below the odometer (not shown) are icons for left and right turn signals along with high beams.
