Clutch feels loose and wont go in gear when started
Posted by vishnu267, Dec 29, 2011
Please Support JNZ Tuning
  1. vishnu267
    vishnu267 Probationary Member
    4
    Joined Apr 6, 2011
    philadelphia, Pennsylvania
    hey guys i need some advice, so today i went to start my car and my clutch felt very loose. so i started driving the car and figured maybe it was just me. soon down the line i noticed the car would barly go into gear and i had to force it. so i pulled over and noticed that all my clutch fluid was gone and the resivoir looked empty. so i went to a nearby pep boys to buy the brake fluid. i got pennzoil dot3 brake fluid. i put the fluid in and it seem to ease a tad bit and stuff but as i kept driving and trying to shift it seemed to be that it didnt really even get better. so i noticed that when the car is turned off it will go right into all gears with no problem at all but when the car is started and i step on the clutch it wont go into gear unless i force it or start the car in a gear already. so does this mean that i definatly need a new clutch? or a flywheel? or what? ### let me know asap what u guys think! thanks
    when i step on the clutch it will go down but it feels so loose almost as if theres no springs or anything in it but the petal does come back up when i take my foot off of the clutch
    Log in/Register to remove ads
    My DSM:
    Loading...
  2. 1996dsm
    1996dsm Proven Member
    351
    Joined Jan 15, 2008
    Fort Worth, Texas
    didn't you have this thread open already?
    My DSM:
    1995 Eagle Talon TSi AWD
    Street Build
    503.2 whp   462.4 lb/ft
    Loading...
  3. projx
    projx Probationary Member
    Joined Jan 3, 2012
    Brooklyn, New York
    I have exactly this problem aswell at this moment. On a cold start it will go into any gear, After the car warms up it will start grinding and eventually wont go into any gear unless i force it or it feels like it. My pedal feels very soft.... Any solutions from anyone?
  4. vishnu267
    4
    Joined Apr 6, 2011
    yeah i know what u mean and the advice i got was to first things first check and make sure u have clutch fluid in the resivior, then bleed the line to get all the air out of the system and it should be better. if not, then u either have to change ## master cylinder or ## slave cylinder. i bleed my line and it got better for awhile and then it started doing it again so idk but i think it might be my master cylinder or i might have a hydrolic leak
    My DSM:
    Loading...
  5. Cdaug720
    Cdaug720 Probationary Member
    22
    Joined Mar 16, 2011
    Layton, Utah
    I've had the same issue lately, but I'm not leaking any fluid at all and my reservoir is full. I replaced the slave cylinder and bled the lines recently and it fixed the problem for a little while, and now it has showed up again. But if i pump my clutch pedal a few times, it glides into gear like butter! any thoughts?
    My DSM:
    Loading...
  6. Boosted DSM 32
    Boosted DSM 32 Proven Member
    433
    Joined Aug 21, 2011
    McDonald, Ohio
    Ive had the exact same problem with my 95' gsx!!! when the cars cold it goes into gear just fine and dandy but the clutch pedal feels "mushy" and once the car heats up it doesnt want to go into gear and you have to force it in and it will do a slight grind when you put it in gear.. I just replaced the slave cylinder and bleed the clutch but it still does the same thing..? there is a slight drip by my clutch pedal and ive had a few dsm guys tell me i need a maste r cylinder as well? could that be the problem were all having? :hmm:
    My DSM:
    1990 Mitsubishi Eclipse GSX
    12.088 @ 120.270 MPH
    Loading...
  7. Abe'sGST
    Abe'sGST Proven Member
    512
    Joined Aug 27, 2011
    Goldsboro, North Carolina
    Okay, first thing to do is check your fluid and see if its full, after that check for any leaks around the clutch master cylinder, line, slave cylinder and even inside your car at the top of your clutch pedal. From what you have said i'm guessing you have a leak in one of those places, if not try bleeding your clutch and see how that turns out
    Loading...
  8. Boosted DSM 32
    433
    Joined Aug 21, 2011
    McDonald, Ohio
    Ive just replaced the slave cylinder and its holding fluid.. and up by the top of the clutch pedal there is a slight drip that my dad seen when he was taking a look up there.. and i had bleed the clutch and still no luck im almost positive my master cylinder is bad
    My DSM:
    Loading...
  9. vishnu267
    4
    Joined Apr 6, 2011
    hmm im wondering the same thing so maybe the problem is the master cylinder and not the slave cylinder or is it recommended to just change them both? my fluid is a really dirtyish blackish looking color, what does that mean?
    My DSM:
    Loading...
  10. LTUDSM
    LTUDSM Proven Member
    1,323
    4
    Joined Jun 27, 2005
    Morrisville, Pennsylvania
    That means,that thefluid is old
    Loading...
  11. vishnu267
    4
    Joined Apr 6, 2011
    but the fluid cant be old because remember the resevoir was completly empty and i put new fluid in it and bleed the master cylinder so idk exactly but the fluid was new fluid that wasnt even 2 weeks old
    My DSM:
    Loading...
  12. projx
    Joined Jan 3, 2012
    Brooklyn, New York
    My res was full, even after sitting there for a month i checked it still at the same spot. I looked under the dash and saw white sticky fluid on the master. So im going to replace the master/slave/clutch/clutchline in a few weeks gotta order the parts tomorrow. Ill check back and tell you what it was for my car.
  13. 91gsdohc
    91gsdohc Proven Member
    223
    Joined Jan 25, 2010
    around, Connecticut
    what no one suggested here you can also try to adjust the clutch see if that helps
  14. projx
    Joined Jan 3, 2012
    Brooklyn, New York
    Alright here is what my problem was my clutch fork was bent. So definitively take a look at that, also see if your slave cylinder screws are lose!
    P.S Clutch fork is broken in picture because tried to bend it back for sh**s and giggles and it snapped LOL
  15. vishnu267
    4
    Joined Apr 6, 2011
    oh wow thats crazy man mine was a simple fix it was just my clutch master cylinder so i was lucky my trans and all that didnt have to come down. i changed my clutch master cylinder and since then the car ran great and gave no issues with the shifting at all since then
    My DSM:
    Loading...
  16. Dsm_Bro
    Dsm_Bro Probationary Member
    15
    Joined Sep 30, 2013
    So. Saint. Paul, Minnesota
    Was your master cylinder leaking externally? Im having the same problem, my car stop going into gear when it gets up to operating temp
  17. gsxboostinnj
    gsxboostinnj Proven Member
    37
    Joined Oct 4, 2012
    forked river, New Jersey
    sounds like the master. check for a leak inside the car at the top of the clutch pedal
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
