Clutch drag won't go away.
Posted by EclipseOwner95, Nov 21, 2012
Drivetrain Tech - 4G63 transmission, clutch, flywheel, driveshaft, gears, differentials, transfer case, shifter, etc.
Please Support Strictly Import Motorsports
  1. EclipseOwner95
    EclipseOwner95 Proven Member
    DSM Profiles:
    Oct 16, 2002
    437
    Jacksonville, Florida
    Alright, I'm pretty much spent on everything I know to try, but maybe I also misunderstand clutch drag a bit as well.
    Is any amount of clutch drag acceptable? Should the car NEVER move when revved up that high with the clutch on the floor?
    I rev the car to right about 7,000 and the car ever so creeps for a moment.
    I have a brand new Shep pedal assembly, literally brand new OEM Slave, Master, Fulcrum Ball, Fork, and TOB. A hard clutch line from master to slave, and the restrictor removed from the slave. I'm running an SB 2700 PP & TZ/B Disc and a brand new XACT Flywheel.
    I've adjusted the clutch pedal more times than I can count, bled the clutch and slave numerous times and it never seems to go away. The car shifts fine at 8000, but I'm just concerned with burning up the synchros.
    My built trans will be going in the car soon and I want to ensure that everything is right before I put it in.
    Any input would be greatly appreciated as I don't really know what else to do.
    #1
  2. myfirstgsx
    myfirstgsx Proven Member
    Sep 25, 2010
    50
    irving tx, Texas
    I had the same problem. if you watch the jacks transmission youtube video on dsm clutch pedal adjustment it will be easy.
    Just have a friend be inside the car and turn the clutch rod clockwise one turn at a time. at the same time you should be under the car pushing slave cylinder lever with your hand. once your friend turns the rod and you can not push the lever in with your hand. Have your friend turn the rod counter clockwise a half turn so that you can push the slave cylinder with your hand. when you can then have him tighten the 14 mm nut in place. then your clutch will be adjusted properly.
    When this is done your car will not creep up when you rev the car up to 7000 rpms and you will not get clutch drag any more.
    Call me with any other questions my name is clayton 469-744-4346
    #2
  3. GST2012GSX
    GST2012GSX Proven Member
    Oct 25, 2010
    86
    Anthony, New_Mexico
    You can watch the video that jafromobile has on his youtube chanel.
    #3
  4. EclipseOwner95
    DSM Profiles:
    Oct 16, 2002
    437
    Thanks, I may give you a call. I have watched Jacks adjustment video. No matter how far clockwise I turn the rod I can always push the slave rod in by hand, even when the rod is so far out that it's about to come loose from the end on the pedal. Also, at the moment the threads of the rod are flush with pedal end.
    I have a brand new OEM master, so I'm sure its good. And I can't possibly see my Shep pedal assembly being bad either, but I suppose anything is possible. I just can't seem to shake this problem and I'm quite concerned.
    #4
  5. MY1GDSM
    MY1GDSM Supporting Member
    DSM Profiles:
    Apr 26, 2007
    2,164
    37
    On the beach, Washington
    Did you by Chance check your Flywheel step even though it's a new Flywheel?
    #5
  6. EclipseOwner95
    DSM Profiles:
    Oct 16, 2002
    437
    No I did not, I assumed that ACT made quality enough of a product to have the step correct. I'm going to pull the trans this weekend and look over everything and have the step checked as well.
    #6
  7. born2tune
    born2tune Proven Member
    Dec 30, 2009
    650
    25
    clarksville, Tennessee
    the flywheel may need to be stepped, also an improperly installed clutch may cause engagement and disengagement issues. last but not least the main shaft may be bent. this happened to some 03' evo's from factory.
    #7
  8. EclipseOwner95
    DSM Profiles:
    Oct 16, 2002
    437
    Well, we can rule out improper clutch installation. I assure you it was done properly. You can also probably rule out a bent input shaft as well, unless I’m the unlucky bastard who has 2 transmissions with bent input shafts. (Problem remained on 2 different trans)
    Flywheel step is certainly a possibility, I’m going to try a new slave, a new clutch line, remove the shim from the pivot ball (My fork is closer to the engine than I think it should be) and have the flywheel step checked out. Other than that I’m buying a PTT if I still have problems haha
    #8
Share This Page
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
