AlexGsxCummins
- 395
- 34
- May 31, 2014
Bremerton,
Washington
hey guys, my car has been down for probably 4 months now with a different issue. finally got the car fixed and i go to test drive the car. clutch works just like it did when it was parked, just fine... i drive about 5-10 miles and i go to push in my clutch and it has little to no pressure till its nearly at the floor. i turn around to drive it home and i could not get it back into 1st gear. i managed to get it into 2nd.. babied it home i tried gravity bleeding it (that's how i previously had it and it was fine for a year) so i feel like maybe i seal went out.. master is NOT leaking into the car and visually looks newer although i didn't ever replace it myself. the slave is NOT leaking and appears to look very old... while bleeding i would get no air bubbles while gravity bleeding it then i would sit in the car and pedal started to feel a lot better.. but still not normal and would not go into gear while running. i then read about bleeding the slave i try this and get some huge air bubbles but then my pedal is completely gone to the floor and can not pump it up. so im wondering if its possible to be sucking in air though the slave into the system and maybe this is why it drove fine till about 5-10 miles into my trip. once i press the slave in it makes a bunch of air bubbles.. ideas
