Clicking / Ticking top of motor?
Posted by Drifter27_04, Oct 19, 2009
Please Support VR Speed Factory
  1. Drifter27_04
    Drifter27_04 Proven Member
    310
    Joined Feb 13, 2005
    Winston Salem, North Carolina
    I have been hearing a clicking/ticking noise for the top area of the motor after driving and assumed it was the injectors maybe and never bother to investigate. Well yesterday I was messing around with the timing belt and turned the crank over to align the timing marks and there after I starting hearing the clicking/ticking again but this time really stood out as I have no injectorsOMG in the car as my new injectors have not arrived yet. In knowing that it could be in the valve train I watched the timing marks on the cams just to see if something may move but nothing happened. Any ideas what it maybe and suggestions where to look other than the valve train area. If the lifters are bad would they cause this clicking/ticking noise?
    Log in/Register to remove ads
    My DSM:
    1990 Eagle Talon TSi AWD
    12.140 @ 109.000 MPH
    Loading...
  2. xxsupralvrxx
    xxsupralvrxx Proven Member
    235
    Joined Aug 30, 2007
    Daytona Beach, Florida
    the lifters be a ticking noise would but I dont know if you would hear it just turning the motor over..
    My DSM:
    14.895 @ 100.000 MPH
    Loading...
  3. Drifter27_04
    310
    Joined Feb 13, 2005
    Thats my thoughts also but I am confused at this time and need some suggestions what it maybe or the cause of it. All I know it started after turning the crank to align the timing marks
    My DSM:
    Loading...
  4. Rob10_99
    Rob10_99 Proven Member
    1,658
    Joined May 22, 2005
    Ptown, Arizona
    Could it be the ISC?
    My DSM:
    1998 Eagle Talon TSi AWD
    29.320 @ 55.000 MPH
    Loading...
  5. Drifter27_04
    310
    Joined Feb 13, 2005
    If I started the car it would be a possibility but as I mention I have no injectors at this time in the car and I turned the crank manual by hand and than the clicking/ticking started afterwards.
    My DSM:
    Loading...
  6. Spoolin4Ever
    Spoolin4Ever Proven Member
    1,008
    13
    Joined Apr 24, 2005
    Moses Lake, Washington
    Here is everything I know of that could possibly make a ticking noise when the engine turns (without burning fuel). Most of these are directly up top, but sometimes stuff sounds up top, means it could be up top instead of middle.
    Notice I said possbily. I am in know way saying to go buy and replace all these parts, but test and look at everything possible.
    Lifter (maybe, notr sure because I have the newer lifters), but I don't think they can because not enough pushing on them just by hand.
    Harmonic balancer pulley
    Water pump going out
    Timing belt tensioner (hydraulic tensioner)
    Timing belt tensioner pulley
    Anything with a pulley attached could make a noice when turning over.
    See sometimes stuff sounds like it is up top but it is not alwys the case.
    Loading...
  7. Drifter27_04
    310
    Joined Feb 13, 2005
    Thanks for mentioning all possibilities it may be but I have checked the timing belt area and it seems fine but I will double check to be sure. I will be taking the valve cover off also and checking over all the valve train making sure there as well. I hope to have this done over the weekend and I will tell m findings if any at that time.
    What makes me think its on the valve train is that after driving it the noise it somewhat louder than opposed to turning the motor manually, in which making me think that what every it might be is building pressure and than releasing it when the motor is seating.
    But anymore suggestions is more than welcomed
    My DSM:
    Loading...
  8. Rob10_99
    1,658
    Joined May 22, 2005
    Ptown, Arizona
    ISC is on your Throttle body, your missing injectors have nothing to do with it :D
    My DSM:
    29.320 @ 55.000 MPH
    Loading...
  9. Drifter27_04
    310
    Joined Feb 13, 2005
    Correct, but how would the ISC be affected when manually turning motor over by hand:confused:
    My DSM:
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
