Oldsid
Supporting VIP
- 208
- 3
- Apr 26, 2006
Calgary,
AB_Canada
The first time the engine just died while I was driving. It did not want to start right away so I towed the car home. However, it started later that afternoon and was running fine for about two weeks before it just died while driving to work. This time it does not want to start. I checked the fuel pump and it works. I also checked the ignition and there is no spark to all spark plugs. I swapped the power transistor with a spare good one and it still does not start. I have not had the time to properly test the coils and the power transistor but I noticed something weird. When I put the ignition key in the on position, the check engine comes on and off quickly than goes off a bit longer and this cycle itself.
Is this blinking on and off of the check engine means my ECU is dead?
