tbird
- 170
- 1
- Nov 10, 2002
IndianaUS
I need some tips on how to change the valve seals... im gonna be doing this for a friend how much time can i expcent doing this. and what tools will be needed.....
Note: This feature currently requires accessing the site using the built-in Safari browser.
12sec92Tsi said:Its alot easier if you have the head off of the car as they are much easier to get to. But you can do it with the head on the car if you buy the Miller tool for $190. Here's a link that may be helpful.
http://vfaq.com/mods/Valvestem-seals.html
EZ91Talon said:You do NOT need to remove the head or cams. You WILL need to remove and replace the rocker assemblies. You will also need special tools (valve spring compressor, shop air with spark plug hole adapter). I used to pay a shop to do this, doesn't mean it gets done right. Buy a Haynes manual (under $20), Chapter 2A section 6 explains it all, even how to do it without compressed air.
Do0d. Did you look at the link?hippy said:SO i can do them with out removing my intake and exhaust cams?? How is this i thought the valve springs were underneath the cams??? Tell me more and i have all the tools and air in our shop!! I need to find more info thanks!!
woodigopoopy said:i used a broken drill press some wood and grease and a pipe that was cut to fit
Ravenous said:Wow, I am struggling with this thing and I am not a weak guy. I tried to do it with a socket and just push hard, but I cannot push hard enough to get it to move. Just wanted to say kudos to the awesomeness...
snowboard1 said:When I replaced my valve stem seals I did the whole job. Took the head off replaced and head gasket and every other gasket and put in arp's. Yes you do remove the timing belt. You can get a special valve spring compressor tool for around 10 bucks that will allow you to take the springs off with out taking the head off.
