catch can setup
Posted by Aproductions, Jul 15, 2010
Please Support Race Components Inc
  1. Aproductions
    Aproductions Proven Member
    1,867
    14
    Joined Aug 11, 2009
    Bethlehem, Pennsylvania
    so there are some threads on oil catch can setups but I wanna find out which is the most practical way for us.
    this is what I'm looking at.
    [​IMG][/url][/IMG]
    so the first one will go to the intake and then the valve cover port.
    and the second one will go to the pcv valve then the intake manifold with a check valve between the intake manifold and the catch can.
    both catch cans flow either way.
    Log in/Register to remove ads
    My DSM:
    1999 Mitsubishi Eclipse GSX
    Street Build
    16g   manual
    1999 Mitsubishi Eclipse GST
    Street Build
    50trim   manual
    Loading...
  2. nek
    nek Proven Member
    647
    Joined Apr 17, 2009
    Pittsburgh, Pennsylvania
    both cans flow either way? what do you mean by this. with a pcv in route it is limited to one way which is correct.
    The setup looks good. Basically your using the intake to relieve pressure under boost and using the intake mani to relieve pressure at idle..
    Im pretty sure its not to hard to do it with only one catch can but thats your decision.
    btw just to clear things up.... you go air intake- catchcan- vc and the other is intake manifold- pcv valve - can - vc .... the pvc must be between the im and the catchcan or underboost your catchcan will feel alot of pressure.
    Loading...
  3. kimcheefists
    kimcheefists Proven Member
    308
    3
    Joined Nov 7, 2008
    S. Korea, Asia
  4. Aproductions
    1,867
    14
    Joined Aug 11, 2009
    that part confused me,
    I'm going so the first one will go to the intake and then the catch can and then the valve cover port.
    and the second one will go the pcv valve then the catch can and then the check valve then the intake manifold
    is this okay?
    and before I meant that the catch cans can flow either way like they aren't directional...basically there aren't built in check valves
    thats the 1 I was referring too....there are a few ways to do it in there, I just want the most practical
    My DSM:
    Street Build
    16g   manual
    Street Build
    50trim   manual
    Loading...
Share This Page
Loading...
Ace Race Parts Advanced Fuel Injection Archer Fabrication Boostin Performance ECM Tuning Extreme Turbo Systems ExtremePSI Feal Suspension Fuel Injector Clinic Jacks Transmissions Jackson Auto Machine JNZ Tuning Magnus Motorsports Miller Import Parts Morrison Fabrication & Design OHM Racing Race Components Inc RockAuto RoadSurge Spultronix Performance STM Tuned Strictly Import Motorsports VR Speed Factory
